Hi all,
I’ve been wressling with adding a MQTT Sensor to HA for some time now and I was hoping someone would be able to shed some light on it. Part of the issue is that the examples on the site do not seem to be working…
I checked the instructions on the page : MQTT Sensor - Home Assistant
There is mentioned the “old” way is obsolete and the new method should be used.
When I copy/paste the below example from the page in my configuration.yaml I get the following error
Invalid config for [mqtt]: [sensor] is an invalid option for [mqtt]. Check: mqtt->mqtt->sensor.
mqtt:
- name: "RSSI"
state_topic: "home/sensor1/infojson"
unit_of_measurement: "dBm"
value_template: "{{ value_json.RSSI }}"
availability:
- topic: "home/sensor1/status"
payload_available: "online"
payload_not_available: "offline"
json_attributes_topic: "home/sensor1/attributes"
If I only use the first example HA accepts the config but I do need a name to use with the sensor, when I add that I get the error again.
mqtt:
- state_topic: "home/bedroom/temperature"
Am I doing something wrong, or is this change not yet fully implemented in HA
