I’ve been trying to create a simple scene that will change the colors of my Hue bulbs and my Lifx Z strip at the same time but can’t seem to figure it out. Does someone have an example that they could share?
What I currently have:
- name: Blue Party
entities:
light.cabinets:
state: on
rgb_color: 0,26,129
color_temp: 233
brightness: 255
Hmm okay thank you ill take a look at this. I see they are using the XY color option to set the color, is there a calculator or a chart to convert these to hex colors or RGB colors? I’ve tried passing values of both to Hue and Lifx and they don’t change colors - even when I manually change the colors to blue - look in HA for their values and try and replicate those values in a scene they dont change.
I unfortunately don’t have any RGB lights as of yet but you could try https://home-assistant.io/components/light/. There is a link to a Hue color chart there, looks like you need to create a Hue api account.
The confusion comes from whether or not I need color_temp AND rgb_color or if color_temp or rgb_color are enough? Are the HUE lights different than the LIFX when it comes to that?
If i group the two in a group and set the group to a “blue” color on the color chart, they come back with different values entirely so I guess I’m confused
