Moved this from here in an attempt to keep that topic cleaner and easier to follow question and answers here.
At the current moment, I believe this is pretty straight forward using existing nodes and there is no need for a specialized node to do this. Also, it would require custom mapped properties for every domain/component that is available within Home Assistant.
Maybe what is needed is more examples of how this can be accomplished with the tools available. @walt has a great example above and hereâs another possible solution I put together.
[{"id":"953f4576.faa588","type":"ha-get-entities","z":"6cb9e978.bf4588","server":"8d00ebbc.99a928","name":"Get States","rules":[{"property":"entity_id","logic":"is","value":"^(light|switch|climate)\\.+","valueType":"re"}],"output_type":"array","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":294,"y":80,"wires":[["2dab5a86.e54686"]]},{"id":"821d957.d510168","type":"inject","z":"6cb9e978.bf4588","name":"Store states","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":118,"y":80,"wires":[["953f4576.faa588"]]},{"id":"5bc878cb.d80f08","type":"comment","z":"6cb9e978.bf4588","name":"How I would do store states","info":"","x":152,"y":32,"wires":[]},{"id":"2dab5a86.e54686","type":"function","z":"6cb9e978.bf4588","name":"transform data","func":"const entities = msg.payload.map((e) => {\n const domain = e.entity_id.split('.')[0];\n const payload = {};\n\n switch(domain) {\n case 'switch':\n case 'light':\n payload.domain = domain;\n payload.service = `turn_${e.state}`;\n payload.data = { entity_id: e.entity_id }; \n break;\n case 'climate':\n payload.domain = 'climate';\n payload.service = `set_temperature`;\n payload.data = {\n entity_id: e.entity_id,\n temperature: e.attributes.temperature,\n target_temp_low: e.attributes.min_temp,\n target_temp_high: e.attributes.max_temp,\n operation_mode: e.attributes.operation_mode\n };\n break;\n }\n return payload;\n});\n// Save the states\nflow.set('savedStates', entities);\n\n// create a blank message object with out new payload\nmsg = { payload: entities };\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":80,"wires":[["ceaf42e4.e245d"]]},{"id":"ceaf42e4.e245d","type":"debug","z":"6cb9e978.bf4588","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":646,"y":80,"wires":[]}]
[{"id":"f14f56e1.4d9a28","type":"inject","z":"6cb9e978.bf4588","name":"Store states","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":118,"y":256,"wires":[["3790fc30.12b354","18d6f55.537770b","94a3c52.9fa9738"]]},{"id":"18d6f55.537770b","type":"ha-get-entities","z":"6cb9e978.bf4588","server":"8d00ebbc.99a928","name":"Get Switches","rules":[{"property":"entity_id","logic":"starts_with","value":"switch","valueType":"str"},{"property":"state","logic":"includes","value":"on,off","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":290,"y":256,"wires":[["19e85c0e.f4d1d4"]]},{"id":"94a3c52.9fa9738","type":"ha-get-entities","z":"6cb9e978.bf4588","server":"8d00ebbc.99a928","name":"Get Lights","rules":[{"property":"entity_id","logic":"starts_with","value":"light","valueType":"str"},{"property":"state","logic":"includes","value":"on,off","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":290,"y":208,"wires":[["19e85c0e.f4d1d4"]]},{"id":"297ff244.47ca4e","type":"comment","z":"6cb9e978.bf4588","name":"Easier to follow version","info":"","x":132,"y":160,"wires":[]},{"id":"3790fc30.12b354","type":"ha-get-entities","z":"6cb9e978.bf4588","server":"8d00ebbc.99a928","name":"Get Climate","rules":[{"property":"entity_id","logic":"starts_with","value":"climate","valueType":"str"}],"output_type":"split","output_empty_results":false,"output_location_type":"msg","output_location":"payload","output_results_count":1,"x":290,"y":304,"wires":[["36705576.17a42a"]]},{"id":"19e85c0e.f4d1d4","type":"function","z":"6cb9e978.bf4588","name":"transform data","func":"const payload = {};\npayload.domain = msg.payload.entity_id.split('.')[0];\npayload.service = `turn_${msg.payload.state}`;\npayload.data = { entity_id: msg.payload.entity_id };\n\n// create a blank message object with out new payload\nmsg = { payload: payload };\nreturn msg;","outputs":1,"noerr":0,"x":476,"y":256,"wires":[["2b7e0299.1ce7ae"]]},{"id":"36705576.17a42a","type":"function","z":"6cb9e978.bf4588","name":"transform data","func":"const payloads = [];\nconst payload = {};\npayload.domain = 'climate';\npayload.service = `set_temperature`;\npayload.data = {\n entity_id: msg.payload.entity_id,\n temperature: msg.payload.attributes.temperature,\n target_temp_low: msg.payload.attributes.min_temp,\n target_temp_high: msg.payload.attributes.max_temp,\n operation_mode: msg.payload.attributes.operation_mode\n};\n\n// create a blank message object with out new payload\nmsg = { payload: payload };\nreturn msg;","outputs":1,"noerr":0,"x":476,"y":304,"wires":[["2b7e0299.1ce7ae"]]},{"id":"e254a879.41d408","type":"comment","z":"6cb9e978.bf4588","name":"function nodes could be replaced with a change nodes","info":"","x":596,"y":208,"wires":[]},{"id":"2b7e0299.1ce7ae","type":"join","z":"6cb9e978.bf4588","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"5","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":654,"y":256,"wires":[["b3db19bf.61d8e8"]]},{"id":"472ff71c.c342c8","type":"debug","z":"6cb9e978.bf4588","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1026,"y":256,"wires":[]},{"id":"b3db19bf.61d8e8","type":"change","z":"6cb9e978.bf4588","name":"","rules":[{"t":"set","p":"savedStates","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":832,"y":256,"wires":[["472ff71c.c342c8"]]}]
[{"id":"850eabae.4938f8","type":"inject","z":"6cb9e978.bf4588","name":"Restore states","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":118,"y":432,"wires":[["11eaa9cb.2a8fc6"]]},{"id":"11eaa9cb.2a8fc6","type":"change","z":"6cb9e978.bf4588","name":"Get Saved States","rules":[{"t":"set","p":"payload","pt":"msg","to":"savedStates","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":314,"y":432,"wires":[["fffe299d.b82568"]]},{"id":"20c88906.d20846","type":"debug","z":"6cb9e978.bf4588","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":822,"y":432,"wires":[]},{"id":"fffe299d.b82568","type":"split","z":"6cb9e978.bf4588","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":482,"y":432,"wires":[["915c3c9d.448b"]]},{"id":"915c3c9d.448b","type":"api-call-service","z":"6cb9e978.bf4588","name":"Restore State","server":"ef067c6f.620e6","service_domain":"","service":"","data":"","mergecontext":"","output_location":"payload","output_location_type":"msg","x":640,"y":432,"wires":[["20c88906.d20846"]]}]
As you can see in the above examples the switch
and light
domains are just saving and restoring the state, on/off. But what if some users wanted to also save and restore the brightness level or not. The climate
domain is saving and restoring more than just the state.
Hopefully, this gives people ideas on how to accomplish what theyâre looking to do.
