Example: Timed Switches
I have a couple of switches that i wanted to only allow to run a maximum amount of time, which is configurable by an input_slider. There have been a few times that i have forgotten to turn of my retic when triggering it manually.
This solves all of those problems. It is based around the example automation for turning a light on for 10 minutes.
It performs two functions:
1.Automation Trigger: Switch Turns On
2. Script On: Delay for x minutes
1.Automation Trigger: Switch Turns Off
2. Script Off: turn off delay script (essentially resets the timer if you manually turn off the switch)
Automations:
automation:
- alias: "Pool: Automatically turn off"
    - platform: state
      entity_id: switch.pool
      to: 'on'
    - service: script.turn_on
      entity_id: script.pool_timer
- alias: "Pool: reset timer"
    - platform: state
      to: 'off'
    - service: script.turn_off
Scripts:
script:
  pool_timer:
    alias: "Pool Timer"
    sequence:
      - delay: '00:{{ states.input_slider.pool_run_time.state | int }}:00'
      - service: homeassistant.turn_off
Input Sliders:
input_slider:
  pool_run_time:
    name: Pool Run Time
    initial: 10
    min: 1
    max: 60
    step: 1
Groups
group:
  backyard:
    - switch.pool
    - input_slider.pool_run_time
That’s awesome. I’m setting that up to turn off bedroom lights when they’re left on as well as for the pool pump.
how’d it go with your lights/bore?
It works great. I’ve got a Sonoff POW in a weatherproof enclosure and have automations setup to turn on the pump when if it rains or if it’s windy and then turn off based on what I have the slider set to. Another automation set to turn all of the weather automations off it reaches a daily 9.5 KWh threshhold. I might switch that to a historic statistic sensor and just base it on time rather than power usage. So far it’s been working out very well. Thanks for the inspiration.
Would you share your code?
Automation
      - platform: state
        entity_id: switch.pool_pump
        to: 'on'
  - id: pool_timer_reset
    alias: "Pool: Timer Reset"
      - platform: state
        to: 'off'
  - id: pool_rain_trigger
    alias: "Pool: Rain Trigger"
      - platform: state
        entity_id: 'sensor.dark_sky_precip'
        to: 'rain'
        for:
          hours: 0
          minutes: 15
          seconds: 0
      - service: switch.turn_on
  - id: pool_wind_trigger
    alias: "Pool: Wind Trigger"
      - platform: numeric_state
        entity_id: 'sensor.dark_sky_wind_speed'
        above: 10
  - id: backwash_alert
    alias: "Backwash Alert"
        entity_id: 'sensor.pool_pump_current'
        above: 9.5
      - service: notify.home_assistant
          title: "Pool Pump needs Backwashed"
          message: "Pool Pump needs Backwashed"
  - id: pool_pump_limit
    alias: "Pool Pump Quota"
        entity_id: 'sensor.pool_energy_today'
        above: 9
      - service: switch.turn_off
Script
  pool_timer:
    alias: "Pool Pump Timer"
    sequence:
      - delay: '00:{{ states.input_slider.pool_pump_timer.state | int }}:00'
Input Slider
  pool_pump_timer:
    name: Pool Pump Timer
    initial: 60
    min: 5
    max: 240
    step: 5
Hi Beef-well,
In your example you show a delay in the HH:MM:SS format and the input slider goes to a max of 240. How does HA handle when the MM part is 60 or more. Normally that would need to equate to 01:00:00 which would the expected way. Any idea, does your setup simply work?
Erwin
Hi @palitu @Beef-well
I’m trying to base on your example to use slider input for garden watering.
Configuration:
switch:
  - platform: rpi_gpio
    ports:
      5: Water trees
      6: Water lawn
input_number:
  water_slider:
    name: Watering Run Time
    initial: 20
    min: 1
    max: 90
    step: 1
Automation:
- id: turn_off_lawn_water
  alias: Turn off garden watering
  - entity_id: switch.water_lawn
    platform: state
    to: 'on'
    entity_id: script.water_timer
- id: reset_water_timer
  alias: Reset water timer
  - platform: state
    to: 'off'
Script:
  water_timer:
    alias: "Watering Timer"
    sequence:
      - delay: '00:{{ states.input_slider.water_slider.state | int }}:00'
My problem is: HomeAss throws error on template parsing {{ states.input_slider.water_slider.state | int }}:
2018-03-17 22:19:54 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall script.water_timer>
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/template.py", line 131, in async_render
    return self._compiled.render(kwargs).strip()
  File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 1008, in render
    return self.environment.handle_exception(exc_info, True)
  File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 780, in handle_exception
    reraise(exc_type, exc_value, tb)
  File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/_compat.py", line 37, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 1, in top-level template code
  File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/filters.py", line 653, in do_int
    return int(value)
jinja2.exceptions.UndefinedError: 'None' has no attribute 'state'
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py", line 1010, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/script.py", line 163, in service_handler
    yield from script.async_turn_on(variables=service.data)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/script.py", line 215, in async_turn_on
    yield from self.script.async_run(kwargs.get(ATTR_VARIABLES))
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/script.py", line 105, in async_run
    delay.async_render(variables))
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/template.py", line 133, in async_render
    raise TemplateError(err)
homeassistant.exceptions.TemplateError: UndefinedError: 'None' has no attribute 'state'
While i run the script with static number of minutes it works OK.
Is there workaround? Any other way to read a value from slider?
Hi @elonden,
In this thread there is sophisticated script which derives correct time.
If templates are working for you, this should be good solution.
For me templates don’t work (HA version 0.63.2) :frowning:
@Beef-well How many watts/amps does that pump pull? Are you on a 15a or 20a breaker? And what is the rating of the Sonoff POW?
The pump draws 11 amps max. It’s on a 15 amp circuit along with a couple of receptacles and a light or 2. The sOnOff POW is rated for 15 amps.
ah ok thanks. I’m in search for a 20amp switch and tough to come by. I def don’t want to go higher in the event of overdraw.
You could make your own. I’ve been playing with ESP8266s and runningTasmota on it you could get a more robust relay and do what you’re wanting to do. This is a WS2812 LED Strip controller I put together in a little waterproof box running Tasmota.
Google Photos
It could pretty easily be set up to control a 20 or 25 amp relay.
Looks like your script is still using input_slider. input_slider has been changed to input_number.
See if that helps. I haven’t converted mine to the new version yet. I’ll share my config once I get it updated.
Here is the updated config for my bedroom light timer
input_numbers.yaml
  bedroom_lights:
    name: Bedroom Light Timer
    initial: 15
    min: 5
    max: 60
    step: 5
scripts.yaml
  bedroom_timer:
    alias: "Bedroom Light Timer"
    sequence:
      - delay: '00:{{ states.input_number.bedroom_lights.state | int }}:00'
          entity_id: switch.bed_room
automations.yaml (Created using the Automation editor)
- action:
  - data:
      entity_id: script.bedroom_timer
  alias: Bedroom Light Timer
  condition: []
  - entity_id: switch.bed_room
    platform: state
    to: 'on'
- action:
  - data:
  alias: Bedroom Light Timer Reset
  condition: []
    platform: state
    to: 'off'
Hi, would you mind to post a screenshot of the automation editor you configured?
I am messing with the syntax and home assitant is complaining about the code itself, when I copy/paste it.
Thx
Andreas
i got it to work , thanks to you @palitu , i had these water pumps that needed to work on timers as per my input…this sorted it nicely.
Cool!
i use them a bit :slight_smile:
Thanks @Beef-well! Used it for a snooze function to turn off my bedroom tv. Works flawlessly! :smiley:
