how’d it go with your lights/bore?
It works great. I’ve got a Sonoff POW in a weatherproof enclosure and have automations setup to turn on the pump when if it rains or if it’s windy and then turn off based on what I have the slider set to. Another automation set to turn all of the weather automations off it reaches a daily 9.5 KWh threshhold. I might switch that to a historic statistic sensor and just base it on time rather than power usage. So far it’s been working out very well. Thanks for the inspiration.
Would you share your code?
Automation
- platform: state
entity_id: switch.pool_pump
to: 'on'
- service: script.turn_on
entity_id: script.pool_timer
- id: pool_timer_reset
alias: "Pool: Timer Reset"
- platform: state
to: 'off'
- service: script.turn_off
- id: pool_rain_trigger
alias: "Pool: Rain Trigger"
- platform: state
entity_id: 'sensor.dark_sky_precip'
to: 'rain'
for:
hours: 0
minutes: 15
seconds: 0
- service: switch.turn_on
- id: pool_wind_trigger
alias: "Pool: Wind Trigger"
- platform: numeric_state
entity_id: 'sensor.dark_sky_wind_speed'
above: 10
- id: backwash_alert
alias: "Backwash Alert"
entity_id: 'sensor.pool_pump_current'
above: 9.5
- service: notify.home_assistant
title: "Pool Pump needs Backwashed"
message: "Pool Pump needs Backwashed"
- id: pool_pump_limit
alias: "Pool Pump Quota"
entity_id: 'sensor.pool_energy_today'
above: 9
- service: switch.turn_off
Script
pool_timer:
alias: "Pool Pump Timer"
- delay: '00:{{ states.input_slider.pool_pump_timer.state | int }}:00'
- service: homeassistant.turn_off
Input Slider
pool_pump_timer:
name: Pool Pump Timer
initial: 60
min: 5
max: 240
step: 5
Hi Beef-well,
In your example you show a delay in the HH:MM:SS format and the input slider goes to a max of 240. How does HA handle when the MM part is 60 or more. Normally that would need to equate to 01:00:00 which would the expected way. Any idea, does your setup simply work?
Erwin
I’m trying to base on your example to use slider input for garden watering.
Configuration:
switch:
- platform: rpi_gpio
ports:
5: Water trees
6: Water lawn
input_number:
water_slider:
name: Watering Run Time
initial: 20
min: 1
max: 90
step: 1
Automation:
- id: turn_off_lawn_water
alias: Turn off garden watering
- entity_id: switch.water_lawn
platform: state
to: 'on'
entity_id: script.water_timer
- id: reset_water_timer
alias: Reset water timer
- platform: state
to: 'off'
Script:
water_timer:
alias: "Watering Timer"
- delay: '00:{{ states.input_slider.water_slider.state | int }}:00'
My problem is: HomeAss throws error on template parsing {{ states.input_slider.water_slider.state | int }}:
2018-03-17 22:19:54 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall script.water_timer>
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/template.py", line 131, in async_render
return self._compiled.render(kwargs).strip()
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/filters.py", line 653, in do_int
return int(value)
jinja2.exceptions.UndefinedError: 'None' has no attribute 'state'
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py", line 1010, in _event_to_service_call
yield from service_handler.func(service_call)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/script.py", line 163, in service_handler
yield from script.async_turn_on(variables=service.data)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/script.py", line 215, in async_turn_on
yield from self.script.async_run(kwargs.get(ATTR_VARIABLES))
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/script.py", line 105, in async_run
delay.async_render(variables))
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/template.py", line 133, in async_render
raise TemplateError(err)
homeassistant.exceptions.TemplateError: UndefinedError: 'None' has no attribute 'state'
While i run the script with static number of minutes it works OK.
Is there workaround? Any other way to read a value from slider?
Hi @elonden,
In this thread there is sophisticated script which derives correct time.
If templates are working for you, this should be good solution.
For me templates don’t work (HA version 0.63.2)
@Beef-well How many watts/amps does that pump pull? Are you on a 15a or 20a breaker? And what is the rating of the Sonoff POW?
The pump draws 11 amps max. It’s on a 15 amp circuit along with a couple of receptacles and a light or 2. The sOnOff POW is rated for 15 amps.
ah ok thanks. I’m in search for a 20amp switch and tough to come by. I def don’t want to go higher in the event of overdraw.
You could make your own. I’ve been playing with ESP8266s and runningTasmota on it you could get a more robust relay and do what you’re wanting to do. This is a WS2812 LED Strip controller I put together in a little waterproof box running Tasmota.
It could pretty easily be set up to control a 20 or 25 amp relay.
Looks like your script is still using input_slider. input_slider has been changed to input_number.
See if that helps. I haven’t converted mine to the new version yet. I’ll share my config once I get it updated.
Here is the updated config for my bedroom light timer
input_numbers.yaml
bedroom_lights:
name: Bedroom Light Timer
initial: 15
min: 5
max: 60
step: 5
scripts.yaml
bedroom_timer:
alias: "Bedroom Light Timer"
- delay: '00:{{ states.input_number.bedroom_lights.state | int }}:00'
entity_id: switch.bed_room
automations.yaml (Created using the Automation editor)
- action:
- data:
entity_id: script.bedroom_timer
alias: Bedroom Light Timer
condition: []
- entity_id: switch.bed_room
platform: state
to: 'on'
- action:
- data:
alias: Bedroom Light Timer Reset
condition: []
platform: state
to: 'off'
Hi, would you mind to post a screenshot of the automation editor you configured?
I am messing with the syntax and home assitant is complaining about the code itself, when I copy/paste it.
Thx
Andreas
i got it to work , thanks to you @palitu , i had these water pumps that needed to work on timers as per my input…this sorted it nicely.
Cool!
i use them a bit
[quote="palitu, post:1, topic:6759"]
`input_slider:`
[/quote]
Thanks for this, was exactly what I needed for my first automation.
FYI I think input_slider: should be input_number:
Is there a way to display the current timer state after button was pressed? Like after pressing the button show a countdown based on the timer.
