I’m playing around modbus.py component.
When i place it into custom_components directory I get exception below.
I’m using untouched file, so I think that some relative import fail.
Someone has any ideas?
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
yield from self.async_device_update()
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 309, in async_device_update
yield from self.hass.async_add_job(self.update)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/config/custom_components/sensor/modbus.py", line 156, in update
result = modbus.HUB.read_holding_registers(
AttributeError: 'NoneType' object has no attribute 'read_holding_registers'
2017-11-15 13:20:57 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.short1 fails
future.result()
2017-11-15 13:20:57 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.float1 fails
future.result()
2017-11-15 13:20:57 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.uint1 fails
future.result()
2017-11-15 13:20:57 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.ushort1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.hroom_4 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.int1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.troom_2 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.float1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.troom_5 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.ushort1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.hroom_3 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.uint1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.hroom_2 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.short1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.hroom_6 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.hroom_5 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.hroom_1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.troom_1 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.troom_3 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.troom_4 fails
future.result()
2017-11-15 13:20:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.troom_6 fails
future.result()
