Hi HA Commuinty
I am having problems integrating my Exchange calendar into HA.
I have tried it according to the following instructions: GitHub - maxlaverse/home-assistant-exchange-calendar: Quick support for Exchange Calendar in Home Assistant
According to the description I have create inside “custom_components” the “exchange_calendar” folder
I copied the files inside this folder:
As requested I have edited the .yaml file:
When I check the configuration, I get the following error:
I am also a bit confused by all the directories. He wrote:
# Go into the Home Assistant's installation directory
cd /srv/homeassistant
# Enter the project's virtual environment
source bin/activate
# Install the exchangelib library
pip3 install exchangelib
# or eventually upgrade it if it's already present but in an older version.
pip3 install exchangelib --upgrade
But I have only the following folders:
Can somebody help me here? Or does anyone know another way to integrate his Exchange calendar into HA?
Thank you for the support
Best regards
Buhli
