Is there a way to exclude an automation from not only the logbook (I’ve done this), but also home-assistant.log?
I’ve written an automation to capture the RSSI value from all my tasmota devices when they report it over MQTT. It works well, but given that I have quite a number of devices all checking in at least every 5 minutes, it’s very chatty in my log file, to the point that I can’t easily pick out anything else.
I’m confident that it won’t be logging any errors, so is there a way I can just get it to not log when this particular automation is triggered and run?
You know, sometimes I feel really dumb when it comes to these things, because changing my log configuration absolutely did the trick. I have been running HA for nearly 2 years now, and literally never looked into configuring the logger component.
I just changed mine from this:
logger:
default: info
to this:
logger:
default: info
logs:
homeassistant.helpers.script: warning
homeassistant.components.python_script: warning
And that pretty much fixed my problem. I didn’t want to lower the log level for homeassistant.components.automation, but that is the only other thing that gets logged for the noisy automation.
