Sonnstein
(Albert Sommer)
1
I have excluded an entity in logbook.yaml, but it still shows up in logbook.
exclude:
entities:
- number.pvse_active_power_limit
![image](https://community-assets.home-assistant.io/original/4X/e/e/d/eedd400284a623156ffc387eee91741f6debda24.png)
The entity is included in recorder.yaml ini order to see it in History.
Has anybody a hint, why it still shows up in the logbook?
tom_l
2
Is the entity id correct?
Have you restarted Home Assistant since making the change (you do need to)?
Sonnstein
(Albert Sommer)
3
After some research on Github, I found out, that my requirement is not possible:
If entities are included in the recorder
, there is no way, to exclude it in logfile
. For me, this is a bad concept.
