Hi
I’ve setup Google Assistant on hassio and it all works fine using this config:
google_assistant:
project_id: ****
client_id: ****
access_token: ****
agent_user_id: ****
expose_by_default: true
exposed_domains:
- switch
- light
- media_player
- climate
I now would like to exclude certain things such as the fire alarm switches, so they can’t be activated by Google Assistant by mistake.
I’ve taken a look at this:
And according to this, I’ve started adding exclusions for my fire alarms as per below in the configuration.yaml:
google_assistant:
project_id: ****
client_id: ****
access_token: ****
agent_user_id: ****
exposed_domains:
- switch
- light
- media_player
- climate
entity_config:
switch.smoke_detector_downstairs_hallway_switch
expose: false
room: downstairs hallway
switch.smoke_detector_upstairs_hallway_switch
expose: false
room: upstairs hallway
Problem is that I then get this error on startup:
2018-03-18 11:05:05 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping values are not allowed here
in “/config/configuration.yaml”, line 169, column 13
2018-03-18 11:05:05 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here
I’ve tried multiple ways, and can’t seem to get this to work!
Any tips appreciated!
Cheers
Will.
