Hi there,
I have several window covers in my house which I want to position depending on the sun brightness and position (azimuth).
I found out that I can give custom attributes to my covers in configuration.yaml. This way, I can split the cover configuration from the actual rules being executed later:
homeassistant:
customize:
cover.cover1:
azimuth_min: 100 # minimum azimuth to set cover position
azimuth_max: 170 # maximum azimuth to set cover position
target_position: 80 # target cover position
excludes: 100 # don't change cover position if it is currently completely down
When programming (as pseudo code), I would do something like this:
for each cover in [cover1, cover2, cover3]:
if sun.azimuth between cover.azimuth_min and cover.azimuth_max:
if cover.current_position not in cover.exclude:
cover.set_position(cover.target_position)
How can I achieve this in an automation? I couldn’t find something similar to a for loop, which iterates over all covers in a list (idealy in parallel, not sequentially).
Best regards,
Michael
