When I have multiple sensors in template/sensors, can one sensor reference another when paying attention to ordering? If sensors at the top get evaluated and stored first, then following sensors could reference them in their state. But that’s an assumption - I’ve not found documentation about this.
More specifically, I am creating flow sensors for GitHub - reptilex/tesla-style-solar-power-card: Home assistant power card mimicking the one tesla provides for the powerwall app.. I get solar power, battery charging/discharging, grid in/out, house consumption as real measurements. With some assumptions, I can guess what the individual flows should be:
- name: "Flow Solar to House"
device_class: power
state_class: measurement
unit_of_measurement: "W"
# Assumption: all produced power is used first for the house.
state: >
{{ min( int(states('sensor.house_consumption'), 0), int(states('sensor.solar_power'), 0) ) }}
- name: "Flow Solar to Battery"
device_class: power
# Assumption: all produced power is used first for the house, so what remains can be used for charging (but might not be used for it).
state: >
{{ max(0, min(int(states('sensor.battery_charging_power'), 0), int(states('sensor.solar_power'), 0) - int(states('sensor.house_consumption'), 0))) }}
- name: "Flow Solar to Grid"
device_class: power
# Assumption: all produced power is used first for the house, then the battery. What remains is feed to the grid.
state: >
{{ max(0, int(states('sensor.solar_power'), 0) - int(states('sensor.house_consumption'), 0) - int(states('sensor.battery_charging_power'), 0)) }}
- name: "Flow Grid to Battery"
device_class: power
# Assumption: The missing enery for charging the battery must come from the grid.
state: >
{{ max(0, int(states('sensor.battery_charging_power'), 0) - int(states('sensor.flow_solar_to_battery'), 0)) }}
- name: "Flow Grid to House"
device_class: power
# Assumption: The missing enery for the house must come first from the battery.
state: >
{{ max(0, int(states('sensor.house_consumption'), 0) - int(states('sensor.solar_power'), 0) - int(states('sensor.battery_discharging_power'), 0)) }}
- name: "Flow Battery to House"
device_class: power
# Assumption: The remaining missing enery for the house must come from the grid.
state: >
{{ max(0, int(states('sensor.house_consumption'), 0) - int(states('sensor.solar_power'), 0) - int(states('sensor.flow_grid_to_house'), 0)) }}
- name: "Flow Battery to Grid"
device_class: power
# Assumption: any unused battery power must go to the grid.
state: >
{{ max(0, int(states('sensor.battery_discharging_power'), 0) - int(states('sensor.flow_battery_to_house'), 0)) }}
Note that for example, “Flow Battery to Grid” uses sensor.flow_battery_to_house which was computed earlier. It seems to work, but perhaps only because it is using some previous value instead of the latest one. I could repeat the expression, but that would make the entire config harder to read and comprehend.
