Expander Card - Removed from HACS?
Over the weekend I decided to start re-designing by dashboard completely, and was going to basically do the entire thing out of EXPANDER CARD:
Alia5/lovelace-expander-card: Expander card for HomeAssistant (github.com)
I was having issues so I ended up removing it with plans to use one of the popular forks.
Issue:
  • I removed expander card and was going to use a fork but now when I type it into HACS, nothing shows up.
*Because it wasnt showing up, I went to go add it as a custom repository manually, but then I get an error for both the main and fork. Also, the fork is being updated right now (6 hours ago).
  • I was frustrated so I manually added all the files using file editor, but theres no .js file in the repository. Instead its a “expanderCard.svelte”.
Im not really too well versed on the specifics of repositories, forks, or branches at all.
At this point, do I just need to wait until this is done, or is there something else I can do? My knowledge in this area & github is very limited.
The js file you can get from release assets…
