Re: Duux integration
I have a DUUX Threesixty 2 which has the new chip and doesn’t support the old methods of adding it to Tuya. My workaround is similar to @acjtaal : use IFTTT Webhooks + Alexa to trigger commands and helpers + automation on the Home Assistant side.
How to:
- In the DUUX App (Gen 2), set up the Alexa integration
- In IFTTT, set up Alexa Actions by mkZense integrations. The free account allows you to set up 3 actions, you will need 2 of them. Make sure to not name them Heater since that can conflict with voice commands. I named them Virtual-Switch-On and -Off.
- In Alexa, set up 2 routines using those virtual buttons as triggers. Add an action → Smart Home → Thermostats → DUUX Threesixty 2.
For powering on, you can also set the desired temperature. What I noticed is that if you set the temperatue, it will turn on in Mode III (high = 1800W). If you don’t set the temperature it uses the lowest Mode I = 800W in my case. I haven’t found a way to power it on in Mode II (~1200W).
In IFTTT: Create applets to turn the heater on and off. I use a webhook request with a specific event
turn_duux_heater_on, which triggers the corresponding Alexa routine through mkzense (e.g.Virtual-Switch-On)
Set up in home assistant
- configure ifttt in configuration.yaml (see IFTTT - Home Assistant)
ifttt:
key: !secret ifttt_key
- Add a helper boolean switch
input_boolean:
duux_heater_switch:
name: DUUX Heater Switch
initial: false
icon: mdi:radiator
- Use an automation to trigger IFTTT events when you toggle the switch
description: "DUUX Heater Alexa + IFTTT On/Off"
mode: queued
- platform: state
entity_id:
- input_boolean.duux_heater_switch
- if:
- condition: state
entity_id: input_boolean.duux_heater_switch
state: "on"
then:
- service: ifttt.trigger
event: turn_duux_heater_on
else:
- if:
- condition: state
state: "off"
then:
event: turn_duux_heater_off
max: 5
That should make the helper switch work (on/off). I’ve added 2 more bonus things:
- Sometimes the Alexa routine doesn’t execute properly / needs a retry. I have a power plug meter, so for example I wrapped the
turn_duux_heater_offin a Repeat/Until the power meter draw is < 1W, where I repeat + sleep 30 seconds until it’s off. - I have a separate temperature sensor in the room, which allows you to use Generic Thermostat - Home Assistant and have a nicer UX. It uses the helper switch to turn things on and off. This is what I added to my
configuration.yaml.
climate:
- platform: generic_thermostat
unique_id: duux_heater_thermostat
heater: input_boolean.duux_heater_switch
initial_hvac_mode: heat
target_sensor: sensor.upstairs_temperature
max_temp: 23
target_temp: 17
target_temp_step: 0.1
sleep_temp: 17
comfort_temp: 19
away_temp: 15
min_cycle_duration:
seconds: 15
And using the Mushroom climate card it looks like this, which means you get temperature control + switch off/on when temperature is reached:
