I use the following Gardena products in my garden:
2 Water Control Bluetooth (01889-20)
2 Irrigation Valve 9 V Bluetooth (1285-20)
1 Garden Pump 6300 (9058-61)
For communication I use a BT Proxy based on ESPHome on an ESP32.
My experiences:
The BT Proxy can keep a maximum of 3 connections open. Although I have 5 devices, one proxy is enough. The connections between clients and proxy are not permanently open.
Originally I had used ESPHome 2024.9.1. I had to restart the proxy from time to time because connections were not released and after a while there were no more free connections.
I am currently using ESPHome 2025.6.1 and no longer have this problem (I think BLE has been improved with 2025.2).
The stability of the connection strongly depends on the distance between client and proxy. The Water Control, for example, also connects over a distance of 4 m, for the pump I had to bring the proxy within 1.5 metres.
As soon as I initiate a command in Home Assistant, it takes approx. 10-15 seconds for the valve to open (establishing the connection to the BT client).
