Experiences with climate control with radiator thermostats + wall thermostat
someone has experience with multiple radiator thermostats and a wall thermostat?
For example with Fibaro thermostat:
and multiple danfoss DAN_LC-13 controllers (one for each radiator):
With this setup it should be possible to configure a temperature for each room but I would like to see configuration examples for HA.
Thanks!
that would be nice to have
Hi I just installed these Danfoss thermostats in our flat. We also have a Netatmo Thermostat to control the gas burner. I have not implemented the automation/schedule for the system but I can’t see why you should not be able to control each room individually. I may have to do some hacks as you have to betray the wall thermostat which is located in our living room by turning off the radiator there to heat only certain rooms, for example the bathroom in the morning.
