Easy and simple questin about he curl commands found here:
# If this sensor returns anything other than 200, there's a problem with Plex!
# Scans every 10 minutes
- platform: command_line
name: Plex HTTP Code
command: curl -I http://192.168.1.X:32400/web/index.html 2>/dev/null | head -n 1 | cut -d$' ' -f2
scan_interval: 600
I have tested it, and it works, no problem. But I have looked for a explanation for the parameters, and can’t realy find it.
Can anyone explain this? → 2>/dev/null | head -n 1 | cut -d$’ ’ -f2
2>
redirects any error output. /dev/null
says basically throw it away. I do not want to see that!
is the pipe character used to do something to the output of the curl
command.
head -n 1
uses the head
command to just select the fist line of the output and discard anything else/
cut -d$’ ’ -f2
uses the cut
command using the space character as a field delimiter. It outputs only the second field (everything between the first & second space characters).
So this question was about your Linux shell, the head
command, and the cut
command.
Sometimes knowing what to search for is half the battle
Very good and informative answer, now I see how it works:)
I was hoping it was clear. Sometimes when you know something so well it is difficult to explain to others,
I have been a UNIX administrator for many years.
