Explanation of smart meter (P1) parameters
Hello.
I don’t really understand what the parameters mean when you read an electricity meter with a P1 dsmr reader.
It says produced, but I have a suspicion that they mean electricity sold?
Why is, for example, “produced” 0 kW when “produced phase 2” is 0.045kW?
hm… I am not 100% sure… but:
consumed Phase1 + Consumed Phase 2 => 3.494 kW
procudec Phase2 => 0.045 kW…
=> 3.494 - 0.045 => 3.449 kW so, the consumed power counter does fit…
your meter should “calculate” imported and exported energy.
When you Export energy on Phase 2 - and at the same time, import on Phase 1 - this will be netted. (means Import 4kw, export 2 kw => net import 2 kw)
Thanks.
I also discovered that “power produced” only shows when theres is “calculations” between the phases.
I thought that in this example, power produced should show 0.045kW but thats not the case.
