For reading a volumetric water content sensor I’m trying to let HA handle the following equation:
The hardest part was already done by a fellow HA user and shared this config:
// for soilless media using calibration equation
// float VWC = ((6.771 * pow(10, -10) * pow(mySensor.sensorTEROS12.calibratedCountsVWC, 3))
// - (5.105 * pow(10, -6) * pow(mySensor.sensorTEROS12.calibratedCountsVWC, 2))
// + (1.302 * pow(10, -2) * mySensor.sensorTEROS12.calibratedCountsVWC))
// - 10.848;
However, I can’t figure out where to put this configuration (scripts?) and what it takes as sensor input (integer or string). My VWC sensor is configured with entity_id: sensor.vwc_s1. That sensor reads a string like ‘2914.01’ in its state.
tom_l
August 17, 2021, 12:33pm
2
It would go in a state based template sensor:
And for more on how to construct a template:
You will find you need to cast your sensor state as a floating point number, like this:
{{ states('sensor.vwc_s1')|float }}
This tool is available to test your templates:
koying
(Chris B)
August 17, 2021, 12:48pm
3
Problem is that neither jinja2 nor HA support pow
Nevermind, not actually really needed if you don’t mess with the number of zeroes
tom_l
August 17, 2021, 12:55pm
4
jinja has x**y
which is x to the power y.
so 5.105 * pow(10, -6)
would be 5.105 * 10 **-6
koying
(Chris B)
August 17, 2021, 12:56pm
5
Yep, just found out
But yeah, at the end of the day 5.105 / 1000000
is not that bad
PS: or 0.000005105
, as most as constants.
123
(Taras)
August 17, 2021, 1:00pm
6
6.771 x 10-10 can be expressed as 6.771e-10
Thanks guys, I’l be going to play around with this
Thanks again for helping me out on this. For the guys that like to copy like me, the working template:
config.yaml
sensors:
c_vwc_s1:
friendly_name: Calculated Volumetric Water Content Sensor 1
unit_of_measurement: "θ"
value_template: >
{{ ((6.771e-10) * (states('sensor.vwc_s1')|float ** 3) -
(5.105e-6) * (states('sensor.vwc_s1')|float ** 2) +
(1.302e-2) * (states('sensor.vwc_s1')|float) -10.848) | round(3) }}
koying
(Chris B)
August 20, 2021, 2:26pm
9
Potterstraat:
(6.771 * 10 **-10)
As Taras mentionned, this can be expressed as 6.771e-10
, which is both more efficient and more readable
