Export data collected to an external influxDB
Hi there,
Is it possible to export (to stream, in fact), the data gathered by entities to an external InfluxDB hosted on another server ?
That is : I don’t want to overload my Home-assistant Raspeberry Pi with the full InfluxDB+Grafana stack.
Thanks for your answers.
E. Lesouef
check out: InfluxDB - Home Assistant (home-assistant.io)
you need to define the ip address of your influxdb instance, it does not matter where is it located as long as the ip is reachable.
Thanks really much. I thought this integration aimed at installing InfluxDB on Home-Assistant. Looks great.
