I don’t know if this is the right category, but I’ll try. I’m new to HA. I would like to write the min/max temperature data to a file once a day so that I can further process this data with Excel or other programs. Find but with the “-platform: file” not the right approach. Can someone from the community help me here?
Greetings from Hamburg
Hi, the following is my automation that writes daily and monthly electricity usage to a CSV file, I think you should be able to adapt this to do what you require:
- id: '1630175809373'
alias: Daily Energy Usage
description: ''
- platform: time
at: 00:01:00
condition: []
- service: notify.energy_log
message: '{{ states(''sensor.date_time'') }};Daily;{{ state_attr(''sensor.energy_usage_day_std'',
''last_period'') }};{{ states(''sensor.energy_cost_last_day_std'') }};{{ state_attr(''sensor.energy_usage_day_offpeak'',
''last_period'') }};{{ states(''sensor.energy_cost_last_day_offpeak'') }}'
- condition: template
value_template: '{{ now().day == 1 }}'
message: '{{ states(''sensor.date_time'') }};Monthly;{{ state_attr(''sensor.energy_usage_month_std'',
''last_period'') }};{{ states(''sensor.energy_cost_last_month_std'') }};{{
state_attr(''sensor.energy_usage_month_offpeak'', ''last_period'') }};{{ states(''sensor.energy_cost_last_month_offpeak'')
mode: single
The following is the associated notifier code from notify.yaml:
- name: energy_log
platform: file
filename: /config/www/csv_logs/energy_log.csv
timestamp: false
Hi Jonah1970,
Thank you, I will test and report tonight.
Regards Frank
Hi Jonah1970,
Due to lack of time it took me longer to implement it, but now it works. Many thanks for the help.
For some reason it is not working like that for me.
I don’t have a separate file that is called notify.yaml
, but I added the code in the configuration.yaml
under the point notify:
, which should be the same.
It works if I use - service: notify.filenotify
but not if I name it different like in the example above - service: notify.energy_log
In more detail:
What works:
In the configuration.yaml
notify:
- platform: file
filename: /config/temp_hum.csv
timestamp: false
Automation:
- platform: time_pattern
minutes: /10
data_template:
message: >-
What not works:
notify:
- name: energy_log
platform: file
filename: /energy_log.csv
timestamp: false
Automation:
minutes: /10
condition: []
message: >-
What also not works:
notify:
- platform: file
filename: /config/energy_log2.csv
timestamp: false
Automation:
minutes: /10
condition: []
- service: notify.energy_log_2
message: >-
Edit:
I did the newest HomeAssistant Update, and now it seems to work perfectly. I don’t know if the upgrade was helping. I did always a real reastart of the system before, but well. Now it works!^^
So you can use the code above for different ways for ideas how to get the same results working
Hello… I am trying to do something similar but don’t know how…
I want to daily generate a file with the reading of the moment state of some sensors… How I do that?
