Export deconz config from filesystem (not webui)?
TL;DR: Is the config from the deconz add-on accessible via the debug terminal?
Context: My SD-card on my rpi3 is falling apart. The base system starts, so I can access the machine via ssh on port 22222, but the webui does not start. Is there a way to fetch the deconz add-on config from disk? I have already moved the deconz dongle to another machine (proxmox). The home assistant on the proxmox is restored from a backup, but the deconz has the factory settings.
