I’m currently trying to make better use of my InkBird ITC-308 WiFi.
My goal is for my Brewing app “Brewfather” to import a JSON File with the current temperature of the ITC-308 every 15 minutes.
Steps Done:
Installed Home Assistant with Docker on a Windows machine running Docker for Windows.
The setup seems to work as intended, as i can reach the site fine.
I’ve also successfully added the ITC-308 to Tuya, and in turn added it to Home Assistant with no issues so far.
Last obstacle to overcome now is export the current state of the ITC-308 as JSON every 15 minutes to a set URL.
I’d love some assistance with this last problem if anyone could
It might be helpful if you could share what the entity looks like that represents the ITC-308. (E.g., what does it look like – entity ID, state & attributes – on the STATES tab of the Developer Tools page.)
For sending the data check out the RESTful Command. Also you’d probably use an automation with a time_pattern trigger set to trigger every 15 minutes that calls the rest_command entity.
Hi Romfrosk,
Old topic (I know) but I was wondering if you were able to pull this info from the Inkbird 308 and feed it into Brewfather?
I would also like to do the same as what you were looking at doing… I’m new here and never run home assistant.
