Actually I use my AdGuard Home as a AddOn in Home Assistant. The idea is to install AdGuard Home as a LX Container in Proxmox. Is there a way to export/import all settings from one system to the other?
Configuration · AdguardTeam/AdGuardHome Wiki · GitHub
You could manually copy the configuration file between the add-on and the lxc. Note that if you use the DHCP server, you’ll need to copy those files separately.
