I have set up a fair bit of my infrastructure using the UI. However, I wanted to export the current config into the yaml file. Is there a way that I can continue where I am but work with the yaml file or do I need to start all over again?
Also wondering if I should even bother with it. I have heard that it is ideal to move forward with the UI anyway? Or is there a third option that I am unaware of.
Hopefully you’re already backing up the entire config folder, which contains a number of hidden files and folders, including .storage/ (but there are more).
If you’re backing up the entire folder then you can restore it to a new install. If you aren’t then you’ve never had a complete backup.
