I have made some improvements to the pyvizio component to add support for settings I’d like to control on my vizio tvs, and I’d like to contribute them back to home-assistant in the best way I can.
A couple of the settings I want to expose do not fit the options for a media_player
: picture mode settings and sleep timer settings.
What’s the best way to expose those controls to home-assistant? I see a couple of different ways that this has been done for other components:
Apple TV has both a
media_player
component and a top-level component. Media player controls go through media player component but other configuration is controlled via the top-level component. -
Kodi exposes additional
services
on themedia_player
component itself, which allows you to script commands against the kodi rpc endpoint. -
The
apple_tv
top-level component has hooks for helping you pair the apple tv and home assistant in the UI, which is currently a manual (command-line) process for vizio tvs. It would be nice to expose the pairing for vizio tvs in the UI as well. Does that require a top-level component or can that be done as amedia_player
as well?
Any direction would be nice here, I’m happy to do whatever is more acceptable to the community.
