Hi all!
i recently signed my 31 day free trial for nabu casa, to check if my sensors would be available for Amazon Alexa.
All my switches, lights, automations were available, processor temperature etc…
The thing is that my MQTT sensors for power metering are not available to expose in nabu casa, is it possible to make it available? see below my MQTT sensors template.
cloud:
alexa:
filter:
include_entities:
- sensor.je05_total-activepower
include_domains:
- sensor
entity_config:
sensor.je05_total-activepower:
name: Total Active Power
description: Total Active Power
ok, i found that if i can add “device_class: power” to the template, nabu casa seems not to recognize this device_class. during my test i changed device_class to “temperature” and unit_of_measurement to “°C”, like below:
and this way nabu casa discovered the sensor, obviously, as a temperature sensor.
so it seems nabu casa can´t discover other sensors for some of the device classes.
to whom may interest, i found that this is not home assistant issue, the thing is Amazon itself doesn´t support power metering units, that´s the reason home assistant accept sensor device class as power but can´t send sensor value to amazon.
