I have two installations of Home Assistant and two separate z-wave controllers due to distance between the networks, however, they are on the same ethernet network. I’d like to control all the z-wave devices from a single Home Assistant installation.
Previously, I’ve done this by running two Z-Wave JS UI docker containers, exposing the appropriate ports, and subscribing a single Home Assistant to both websockets.
I decided to give a Home Assistant Green (running version 2023.12.2) a shot recently and have migrated everything for one system to it and it is functional. However, I think the ports are not exposed outside of HAOS. I can’t connect to port 3000 for the websocket, or 8091 for the UI from a different computer but from within HAOS on the Home Assistant Green the UI and the websocket are working fine.
How can I expose those ports externally so I can hit them from the network? Thanks.
