After trying for three days I am finally going to cry “Uncle”. I had my setup working with access internally and externally through xxxx.duckdns.org before I installed Express VPN on my router to secure my network.
Now I only get partial access (works on the desktop but not on the iPhone through xxxx.duckdns.org, I think because I have my windows hosts file forwarding to my HA ip) internally and no access externally. Works internally all the time through the direct HA ip on all devices.
I’ve tried forwarding the ports through Express VPN (8123, 80) as I had before I installed the VPN. I have the Dynamic DNS service setup through Express VPN to point to my DuckDNS ip. But nothing works
Setup
LAN-to-LAN everything on the same subnet
Modem -> Express VPN Router (WiFi) ASUS AC68U -> TP-Link R600VPN Router (this is where HA is served)
HASSIO
Home Assistant 0.103.5
Networking Related Add-ons
Duck DNS
Nginx Proxy Manager
Dnsmasq
Configuration Files
configuration.yaml
http:
base_url: https://xxxx.duckdns.org
DuckDNS
"lets_encrypt": {
"accept_terms": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
"token": "xxxxxxxxxx",
"domains": [
"xxxxxx.duckdns.org"
"seconds": 300
Nginx Proxy Manager
Dnsmasq
"defaults": [
"8.8.8.8",
"8.8.4.4"
"forwards": [],
"hosts": [
"host": "xxxx.duckdns.org",
"ip": "192.168.x.xxx"
Things I’ve Tried So Far…
Turning on and off all networking add-ons
Port Forwarding as mentioned above
Turning on and off the VPN
Adding port number to end of URL
My goal would to be able to have everything as it was before the VPN but with the VPN in place.
Exteranl and internal access through my duckdns.org URL. Thank you for any help and insight you can provide.
