Hi-Link has two smaller cheaper wifi relay modules:
I would need them to pilot some Electric Air Duct Damper and they are quite cheaper than HLK-SW16 ($56)
Could you please have them supported by HomeAssistant too?
Thanks a lot
Thanks a lot
Out of subject, just flash the ESP on it with ESPHome for example !! No need of dedicated component for it in HA !
HLK-SW16 already has a dedicated HA component, I thought it would be nice to the its little brothers HLK-SW04 & HLK-SW02 too.
I wouldn’t mind using ESPHome as you suggest … but it looks out of my skills. If it is to be my solution, can you please be more specific? Flash what with which firmware and how ?
Author of the hlk-sw16 module here, I can probably add support for those if I have sample hardware or remote access to those modules.
edit: I pulled up some info on those and I think they may use the exact same protocol as the hlk-sw16 so if you want to buy them they will probably work as is.
Hi @jameshilliard
Very nice of you.
I go buy some of these and let you know.
Thanks for the answer.
hi james,
i have this board connected to my network and then ha config is attached
hassio side i have this config
hlk_sw16:
relay1:
host: 192.168.1.99
port: 8080
switches:
0:
1:
2:
3:
4:
5:
6:
7:
8:
9:
a:
b:
c:
d:
e:
f:
attached is the error i keep getting connected disconnected, serched every whre tried few things but its not connecting please suggest what might be going wrong or share your relay page setup so i can get it right
thanks in advace
Gagan
What happens if you try:
telnet 192.168.1.99 8080
hi,
Firstly thank you for quick reply sorry for late reply, when i telnet in to my host which is HLK-sw16 in this case it gives non stop gibberish letters attached in the video and screen shot below hard to make any sense
thanks in advance
Strange, so it seems to be pushing data at least, is this a HLK-SW16?
Can you enable debug logging for this module so that it will log the raw packets?
logger:
default: info
logs:
hlk_sw16: debug
homeassistant.components.hlk_sw16: debug
homeassistant.components.switch.hlk_sw16: debug
@Gagan_Kochar Hi, I am facing similar behavior with my HLK-SW16: disconnect/connect. While disconnected switch state appears as unavailable. Did you find a solution for it?
@jameshilliard
Here is what I have in logs
2020-01-19 06:16:42 INFO (MainThread) [hlk_sw16.protocol] disconnected because of close/abort.
2020-01-19 06:16:42 WARNING (MainThread) [homeassistant.components.hlk_sw16] HLK-SW16 relay1 disconnected
2020-01-19 06:16:42 DEBUG (MainThread) [hlk_sw16.protocol] Protocol disconnected...reconnecting
2020-01-19 06:16:42 WARNING (MainThread) [homeassistant.components.hlk_sw16] HLK-SW16 relay1 connected
2020-01-19 06:16:42 DEBUG (MainThread) [hlk_sw16.protocol] {'0': False, '1': False, '2': False, '3': False, '4': False, '5': False, '6': False, '7': False, '8': False, '9': False, 'a': False, 'b': False, 'c': False, 'd': False, 'e': False, 'f': False}
Is there anything else in your logs? I need to see the full logs, not just the last second, don’t cut off any lines.
So it appears there are multiple variants of the HLK-SW16 MCU firmware which have slightly different behavior. I should have a workaround soon to the timeout issue caused by the different behavior in some units.
This incompatibility should be fixed by this change.
Edit:
Just noting that my fix is now included in the latest home assistant release and was confirmed to fix the issue for @abaksa1.
telnet shows nothing.
Probably the protocol is different.
Here is my simple java command line app to control it
Well I only recently added support for the variants that don’t show anything on telnet(which will just repeatedly disconnect/reconnect like your log shows in home-assistant due to not receiving expected status reports), it looks like you might not be on a new enough version of home-assistant that has a fix to handle both variants.
I’m using the latest HA 0.110.4
I have sent the address of my HLK-SW16 to you via PM. Feel free to debug.
Probably a permanent connection is bad idea.
You need to connect for a short time only to send a command or request states.
Note HA failed to start at all because of this connection issue in the main thread in HLK-SW16 integration.
It makes the entire system very unstable.
The reason for a permanent connection is so that this is a Local Push class integration, see here for more details. Without a persistent connection home assistant would not notice a relay state change until it polls the state, with the current integration I sync the relay state when connecting initially and maintain a connection so that home assistant will immediately be notified of any relay state changes.
Strange, I haven’t seen that behavior myself, I’ve overhauled the integration to use config flow here which might fix that issue.
FYI
I have updated the component to support the early version of HLK-SW16 without RTC clock.
The relay control protocol is little bit different.
