Trying to make use of the actual forecast data, and not only be able to glance at the Graph, or find a single max value, I’ve been exploring the actual Free api made available by https://knutkohl.consulting.
This allows me to compare the provided data, (which changes during the day in showing either tomorrow and today, or yesterday and today, depending on the subset selected)
I’ve set it up in a way, that the actual sensor value template show todays (max) value where applicable, and has all hourly data in its attributes. Made those into a single dictionary for now. Maybe it can be useful to template them out into single entities at a later time.
My Frontend card uses custom:template-entity-row, to show the max of those attributes over the 2 days.
This way, we can come closer to deciding whether the dishwasher should be used now, or better wait until tomorrow during sun production. Or, when that would be low, use the low rate time period. what ever suits your situation
@petro and @thefes helped me out tremendously on the template section, thx again, you make this community shine!
original author and code-owner of the Solar Forecast integration @klaasnicolaas also shared his feedback in the initial stages of this little project. Thanks Klaas!
As that resulted in revealing the unlikelihood of Core HA providing the data set as it is available below in the near future, I pursued here.
Challenge:
as you can see I’ve not yet decided which entity I need to set the automation to update.
There is a strict ratelimit, and not wanting to bash the free service provider (Thanks!) I’ve set the scan_interval to once a day, and only want to update during daytime.
I could add all 5 sensors on this single resource, but havent been able to establish what that does with the ratelimit. Preferably we would be able to update the resource only once, and the sensors would follow suit? Not sure yet.
Anyways, this is what it looks like for now (might add a nice Apexcharts card with the graphed data, but since we have that in core Dashboard, didnt spend much time on that yet. note this holds more data-points which was the whole reason to start this)
some more info-s:
backend package
# Package Solar Forecast Estimate rest sensor met alle attributes
# zie https://swagger.forecast.solar
# @mariusthvdb is also my Github and community handle.
# Automation
# https://www.home-assistant.io/integrations/automation/
automation:
alias: Update solar forecast estimate
platform: time_pattern
minutes: 0
condition:
condition: state
entity_id: sun.sun
state: above_horizon
service: homeassistant.update_entity
entity_id:
# Rest
# https://www.home-assistant.io/integrations/rest
# {% set midnight = today_at() %}
# {% set tomorrow = midnight + timedelta(days=1) %}
# {% set data = value_json.result.watts.items()
# | rejectattr('0', '<=', midnight.isoformat())
# | rejectattr('0', '>=', tomorrow .isoformat())
# | sort(attribute='1', reverse=True) %}
# {{ (data | first | default(("Unknown",0)))[1] }}
# Thank you @Petro !
# {{ (value_json.result.watts.items()
# | list | sort(attribute='1', reverse=True)
# | first | default(("Unknown",0)))[1] }}
# {{ value_json.result.watts.items()
# | rejectattr('0', '<', today_at().isoformat())
# | rejectattr('0', '>=', (today_at() + timedelta(days=1)).isoformat())
# | map(attribute='1') | max }}
# items are templastes in KVP's. [0] selects timestamp, [1] selects value
# for Frontend:
# {% set peak = (data | first | default(("Unknown",0))) %}
# {{ peak[1] }} W om {{ as_datetime(peak[0]).strftime('%-H') }} uur
# {% set data =
# value_json.result.watt_hours_day.items() | list
# {{ peak[1] }} W op {{ as_datetime(peak[0]).strftime('%-d-%-m') }}
# thank you @TheFes !
# rest sensors calculating the 'todays' value, frontend showing the highest of 2 days
# in secondary
rest:
- resource: !secret solar_forecast_api
scan_interval: 86400
- unique_id: solar_forecast_estimate_watts
name: Solar Forecast estimate watts
icon: mdi:solar-power
unit_of_measurement: W
value_template: >
{% set today = now().strftime('%Y-%m-%d') %}
|selectattr('0','search',today)
|sort(attribute='1',reverse=True) %}
{{(data|first|default(('Unknown',0)))[1]}}
json_attributes_path: "$.result"
json_attributes:
- watts
- unique_id: solar_forecast_estimate_watt_hours_period
name: Solar Forecast estimate watt hours period
icon: mdi:solar-power-variant
unit_of_measurement: Wh
value_template: >
{% set data = value_json.result.watt_hours_period.items()
json_attributes:
- watt_hours_period
icon: mdi:sun-clock-outline
value_template: >
{% set data = value_json.result.watt_hours.items()
json_attributes:
- watt_hours
- unique_id: solar_forecast_estimate_watt_hours_day
name: Solar Forecast estimate watt hours day
icon: mdi:calendar-today
value_template: >
{{value_json.result.watt_hours_day[today]}}
# {% set today = now().strftime('%Y-%m-%d') %}
# {{(value_json.result.watt_hours_day.items()|list
# |selectattr('0','search',today)
# |sort(attribute='1',reverse=True)
# |first|default(('Unknown',0)))[1]}}
json_attributes:
- watt_hours_day
- unique_id: solar_forecast_estimate_message
name: Solar Forecast estimate message
icon: mdi:message-text-outline
value_template: >
{% set type = value_json.message.type %}
{{type if type == 'success' else value_json.message.text}}
json_attributes_path: "$.message"
json_attributes:
- code
- type
- text
- info
- ratelimit
# Template
# https://www.home-assistant.io/integrations/template/
template:
- sensor:
- unique_id: solar_forecast_estimate_current_hour
name: Solar forecast current hour
state: >
{% set nu = now().replace(minute=0, second=0 , microsecond=0).isoformat() %}
{% set watts = state_attr('sensor.solar_forecast_estimate_watts','watts')%}
{% set data = watts.items() %}
{{watts[nu] if nu in watts else 'No production estimated'}}
icon: mdi:sun-clock
# guard against `now()` not being in the dictionary because no data is provided by the api at sun = down.
# could probably also test for sun state too ;-)
# Rest
# https://www.home-assistant.io/integrations/sensor.rest/
# sensor:
# - platform: rest
# unique_id: solar_forecast_estimate_rest_sensor
# name: Solar Forecast estimate
# resource: !secret solar_forecast_api
# scan_interval: 3600
# value_template: >
# {{now()}}
# headers:
# Accept: "application/json"
# json_attributes_path: "$.result"
# json_attributes:
# - watts
# - watt_hours_period
# - watt_hours
# - watt_hours_day
and Dashboard card:
type: entities
card_mod:
class: class-header-margin
title: Solar Forecast estimates
state_color: true
entities:
- type: custom:template-entity-row
entity: sensor.solar_forecast_current_hour
secondary: >
Actuele opbrengst: {{states('sensor.zp_actuele_opbrengst')|int(default=0)}} W
- type: divider
entity: sensor.solar_forecast_estimate_watts
secondary: >
{% if states[config.entity] is not none %}
{% set attr =
state_attr(config.entity,'watts').items()
{% set peak = (attr|first| default(('Unknown',0))) %}
{{peak[1]}} W op {{as_datetime(peak[0]).strftime('%-d-%m')}} om {{as_datetime(peak[0]).strftime('%-H')}} uur
{% else %} Initializing
{% endif %}
entity: sensor.solar_forecast_estimate_watt_hours_period
secondary: >
{% set attr =
state_attr(config.entity,'watt_hours_period').items()
{% endif %}
secondary: >
{% set attr =
state_attr(config.entity,'watt_hours').items()
{{peak[1]}} W op {{as_datetime(peak[0]).strftime('%-d-%-m')}}
{% endif %}
entity: sensor.solar_forecast_estimate_watt_hours_day
secondary: >
{% set attr =
state_attr(config.entity,'watt_hours_day').items()
{% endif %}
entity: sensor.solar_forecast_estimate_message
secondary: >
{% set limit = state_attr(config.entity,'ratelimit').limit %}
{% set left = state_attr(config.entity,'ratelimit').remaining %}
Limit: {{limit}}, Remaining: {{left}}
{% endif %}
- entity: automation.update_solar_forecast_estimate
secondary_info: last-triggered
and an initial Apex-charts card:
- type: custom:apexcharts-card
graph_span: 48h
update_interval: 1h
header:
show: true
experimental:
color_threshold: true
span:
start: day
now:
show: true
label: Now
yaxis:
- id: estimate
decimals: 0
- id: actueel
decimals: 0
show: false
apex_config:
plotOptions:
bar:
columnWidth: 100%
series:
- entity: sensor.solar_forecast_estimate_watts
yaxis_id: estimate
data_generator: |
let res = []; for (const [key, value] of
Object.entries(entity.attributes.watts)) {
res.push([new Date(key).getTime(), value]);
} return res;
color_threshold:
- value: 0
color: moccasin
- value: 500
color: khaki
- value: 1000
color: yellow
- value: 1500
color: gold
- value: 2000
color: orange
- value: 2500
color: darkorange
- value: 3000
color: tomato
- value: 3500
color: sandybrown
- value: 4000
color: peru
- value: 4500
color: orangered
- value: 5000
color: maroon
- value: 5500
color: purple
- value: 6000
color: darkred
type: column
show:
extremas: true
# legend_value: true
# opacity: 1
# float_precision: 0
stroke_width: 8
- entity: sensor.zp_actuele_opbrengst
yaxis_id: actueel
# transform: return x /1000;
# unit: kW
type: line
stroke_width: 1
extend_to: false
color: grey
group_by:
func: min
duration: 60m
# show:
there’s some extra detail to work out there (better color thresholds, and,
why does the legend show 0…
thanks @vingerha and @studioIngrid for helping me find the construction for the data_generator, converting the dict to a list!
combining those with
and one can see the foreshadows of some better logic, for deciding when to fire which utility
