Home Assistant automation blueprint: Extended Away state
Github repository
Home Assistant Blueprints Exchange
Installation to Home Assistant
Or import to HA from GitHub
https://github.com/Reproduktor/ExtendedAwayStateBlueprintHassio/blob/64d16860f8f4637aff34cc243499ada4981d6161/ExtendedAwayState.yaml
Description
This automation maintains a boolean helper, indicating if a person or device is away from home for an extended (configurable) amount of time. To configure, two helpers need to be provided for the automation to function properly.
For increased robustness, the automation is triggered when Hassio restarts, as well as every midnight, and either resets the Extended away status (if the person is at home), or starts the timer (if the person is not at home). This way, even if leaving/entering home zone events are missed for some reason, the extended away state will eventually be corrected.
Parameters
- Person An entity to track. It is designed for either a person entity, or device_tracker entity, but any entity which indicates home presence by being set to state ‘home’ will work
Extended away indicator A helper of type
input_boolean
. This value will be set by this automation toon
, when the person is away from home for more than the defined amount of time. The value will be reset tooff
as soon as the person returns home. - Extended away time Time, in hours, after which the person is considered away for an extended amount of time.
Timer A helper of type
timer
, which is needed by this automation to count down when the person leaves from home.
Hints
I use this automation for every home member independently. My schema is:
- Create
input_boolean
helpers for each person:input_boolean.extendedaway_person1
,input_boolean.extendedaway_person2
, … - Create
timer
helpers for each person:timer.extendedawaytimer_person1
,timer.extendedawaytimer_person2
, … - Based on this blueprint, create automations for each person:
Maintain an 'extended away' state for Person1
,Maintain an 'extended away' state for Person2
Practical applications
I use the state for controlling, to whom the notifications from Home Assistant will be sent. In my scenario, I have a script which delivers a given message to family members, that are home-ish. The script is like this:
notify_family_members_at_home_these_days:
alias: Notify family members at home these days
icon: mdi:bell-badge-outline
description: "Whoever is not away for extended period of time, gets notified."
mode: queued
max: 10
fields:
message:
description: "Message to send"
selector:
text:
title:
description: "Title of the message to send"
selector:
text:
sequence:
- choose:
- conditions:
- condition: state
entity_id: input_boolean.extendedaway_person1
state: 'off'
sequence:
- service: notify.mobile_app_person1
message: "{{ message }}"
title: "{{ title }}"
- choose:
- conditions:
- condition: state
entity_id: input_boolean.extendedaway_person2
state: 'off'
sequence:
- service: notify.mobile_app_person2
# ... etc ...
default: []
Blueprint
blueprint:
name: Maintain an 'extended away' state for a person
description: Select a person, a boolean helper, the desired time period, and a timer helper,
and this automation will take care of maintaining the provided boolean with a value indicating
if the given person is away from home for more than the given amount of time.
domain: automation
input:
person:
description: 'Person, or tracker, to watch (e.g. person.dad, or device_tracker.iphone).'
selector:
entity:
extended_away_boolean:
name: Extended away indicator
description: 'A helper of type input_boolean to set.'
selector:
entity:
domain: input_boolean
extended_away_time:
name: Extended away time
description: 'The time, after which a person is considered to be Extended Away (in hours).'
default: 24
selector:
number:
min: 1
max: 168
step: 1
unit_of_measurement: hrs
mode: box
extended_away_timer:
description: 'A helper timer this automation needs to keep track of the time a person is being away from home.'
selector:
entity:
domain: timer
source_url: https://github.com/Reproduktor/ExtendedAwayStateBlueprintHassio/blob/master/ExtendedAwayState.yaml
- platform: event
event_type: timer.finished
event_data:
entity_id: !input 'extended_away_timer' #timer.extendedawaytimer_ocino
- platform: state
entity_id: !input 'person'
to: home
for:
hours: 0
minutes: 0
seconds: 0
- platform: state
- platform: homeassistant
event: start
- platform: time_pattern
minutes: '01'
seconds: '30'
hours: '0'
condition: []
variables:
var_hours: !input 'extended_away_time'
var_seconds: "{{ var_hours | int * 3600 }}"
- choose:
- conditions:
- condition: trigger
sequence:
entity_id: !input 'extended_away_boolean'
- conditions:
sequence:
- service: timer.start
duration: '{{ var_seconds }}'
- conditions:
sequence:
- service: timer.cancel
- service: input_boolean.turn_off
- conditions:
- condition: or
conditions:
sequence:
- choose:
- conditions:
- condition: not
conditions:
- condition: state
state: active
- condition: state
state: home
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: home
sequence:
default: []
default: []
mode: queued
max: 5
