Extended Gauge Card
Hi there
I thought it was time to release my first Lovelace card. It’s an extended Gauge Card featuring lower and upper bounds for each segment, display of minimum and maximum values, and more.
Here’s the detailed feature list:
  • UI-based configuration for easy setup
  • Backward compatibility with YAML configuration
  • Shows minimum and maximum value
  • Individually configurable segments, each with a lower and upper bound, a color, and a replacement value
  • Unlimited number of segments
  • Displays the values of segment bounds
  • Can be shown with or without a needle
The Extended Gauge Card is a spin-off of a larger project I’ve been working on for quite some time.
You can find the documentation here and download the card here
I’m excited to hear what you think of it and how you use it!
The numbers are good.
I am new to HA and Yaml. I am liking this more than the default gauges, is it possible to replace the segment numbers with icons?
if not would it be possible to add this feature in one of the later updates?
Hi, is it possible to enable the touch graph like the original gauge?
