[extended_openai_conversation] 0.0.8-beta2 (Prerelease Version) is now available
Introduction
The extended_openai_conversation added sqlite function in 0.0.8-beta2, which makes chatgpt accessible to Home Assistant database.
There are two ways to register functions:
  1. Let gpt generate a query.
    • pros
      • Ideally, you can ask anything, and gpt will retrieve any data for you
    • cons
      • hard to validate if query is only using entities that are exposed.
      • gpt often makes a query that user asked. (hallucination)
  2. User manually defines a query, and let gpt call your query.
    • pros
      • able to verify only exposed entities are used (unless there’s sql injection attack by gpt)
      • since query is verified, less hallucination.
    • cons
      • have to make all functions that will be called when user asks.
Function
1. SQL generated by LLM
  • Try with few examples and find one that best fits for your case.
  • Tweak name and description to find better result of query
simple (with no validation)
- spec:
    description: >-
      Use this function to query histories from Home Assistant SQLite database.
      Example:
        Question: How long was livingroom light on in Nov 15?
        Answer: SELECT datetime(s.last_updated_ts, 'unixepoch', 'localtime') last_updated, s.state, old.state as prev_state FROM states s INNER JOIN states_meta sm ON s.metadata_id = sm.metadata_id INNER JOIN states old ON s.old_state_id = old.state_id WHERE sm.entity_id = 'switch.livingroom' AND s.state != old.state AND datetime(s.last_updated_ts, 'unixepoch', 'localtime') BETWEEN '2023-11-15 00:00:00' AND '2023-11-15 23:59:59'
    parameters:
      type: object
      properties:
        query:
          type: string
          description: A fully formed SQL query.
  function:
    type: sqlite
with minimum validation (still not enough)
- spec:
    description: >-
      Example:
        Question: When did bedroom light turn on?
        Answer: SELECT datetime(s.last_updated_ts, 'unixepoch', 'localtime') last_updated_ts FROM states s INNER JOIN states_meta sm ON s.metadata_id = sm.metadata_id INNER JOIN states old ON s.old_state_id = old.state_id WHERE sm.entity_id = 'light.bedroom' AND s.state = 'on' AND s.state != old.state ORDER BY s.last_updated_ts DESC LIMIT 1
        Question: Was livingroom light on at 9 am?
        Answer: SELECT datetime(s.last_updated_ts, 'unixepoch', 'localtime') last_updated, s.state FROM states s INNER JOIN states_meta sm ON s.metadata_id = sm.metadata_id INNER JOIN states old ON s.old_state_id = old.state_id WHERE sm.entity_id = 'switch.livingroom' AND s.state != old.state AND datetime(s.last_updated_ts, 'unixepoch', 'localtime') < '2023-11-17 08:00:00' ORDER BY s.last_updated_ts DESC LIMIT 1
    parameters:
      type: object
      properties:
        query:
          type: string
  function:
    type: sqlite
    query: >-
      {%- if is_exposed_entity_in_query(query) -%}
        {{ query }}
      {%- else -%}
        {{ raise("entity_id should be exposed.") }}
      {%- endif -%}
2. Defined SQL manually
2-1. get_state_at_time
- spec:
    description: >
      Use this function to get state at time
    parameters:
      type: object
      properties:
        entity_id:
          type: string
          description: The target entity
        datetime:
          type: string
          description: The datetime in '%Y-%m-%d %H:%M:%S' format
      required:
        - entity_id
        - datetime
        - limit
  function:
    type: sqlite
    query: >-
      {%- if is_exposed(entity_id) -%}
        SELECT datetime(s.last_updated_ts, 'unixepoch', 'localtime') as state_updated_at, s.state
        FROM states s
        WHERE sm.entity_id = '{{entity_id}}'
          AND datetime(s.last_updated_ts, 'unixepoch', 'localtime') < '{{datetime}}'
        LIMIT 1
      {%- else -%}
      {%- endif -%}
2-2. get_states_between
- spec:
    description: >
      Use this function to get non-numeric states between two dates.
    parameters:
      type: object
      properties:
        entity_id:
          type: string
        state:
          type: string
          description: The state
        state_operator:
          type: string
          description: The state operator
          enum:
        start_datetime:
          type: string
          description: The start datetime in '%Y-%m-%d %H:%M:%S' format
        end_datetime:
          type: string
          description: The end datetime in '%Y-%m-%d %H:%M:%S' format
        order:
          type: string
          description: The order of datetime, defaults to desc
          enum:
          - asc
          - desc
        page:
          type: integer
          description: The page number
        limit:
          type: integer
          description: The page size defaults to 10
      required:
        - entity_id
        - start_datetime
        - end_datetime
        - order
        - page
        - limit
  function:
    type: composite
    sequence:
      - type: sqlite
        query: >-
            SELECT datetime(s.last_updated_ts, 'unixepoch', 'localtime') as updated_at, s.state
            FROM states s
              AND (('{{state | default('')}}' = '') OR (s.state {{state_operator | default('=')}} '{{state | default('')}}'))
              AND datetime(s.last_updated_ts, 'unixepoch', 'localtime') >= '{{start_datetime}}'
              AND datetime(s.last_updated_ts, 'unixepoch', 'localtime') < '{{end_datetime}}'
            ORDER BY s.last_updated_ts {{order}}
            LIMIT {{(page-1) * limit}}, {{limit}}
          {%- else -%}
          {%- endif -%}
        response_variable: data
      - type: sqlite
        single: true
        query: >-
          SELECT count(*) as count
          FROM states s
        response_variable: total
      - type: template
        value_template: '{"data": {{data}}, "total": {{total.count}}}'
2-3. get_total_time_of_entity_state
- spec:
    description: >
      Use this function to get total time of state of entity between two dates
    parameters:
      type: object
      properties:
        entity_id:
          type: string
        state:
          type: string
          description: The non-numeric target state
        start_datetime:
          type: string
        end_datetime:
          type: string
      required:
        - entity_id
        - state
        - start_datetime
        - end_datetime
  function:
    type: composite
    sequence:
      - type: sqlite
        query: >-
            WITH stat_data AS (
              WITH lead_data AS (
                SELECT datetime(old.last_updated_ts, 'unixepoch', 'localtime') AS prev_last_updated,
                  old.state AS prev_state,
                  datetime(s.last_updated_ts, 'unixepoch', 'localtime') AS last_updated,
                  s.state,
                  COALESCE(LEAD(datetime(s.last_updated_ts, 'unixepoch', 'localtime')) OVER (ORDER BY s.last_updated), '{{end_datetime}}') AS lead_last_updated,
                  LEAD(s.state) OVER (ORDER BY s.last_updated) AS lead_state
                FROM states s
                  AND datetime(s.last_updated_ts, 'unixepoch', 'localtime') BETWEEN '{{start_datetime}}' AND '{{end_datetime}}'
              SELECT max(prev_last_updated, '{{start_datetime}}') AS prev_last_updated,
                prev_state,
                last_updated AS last_updated,
                state
              FROM lead_data
              WHERE last_updated = (SELECT MIN(last_updated) FROM lead_data)
              UNION ALL
              SELECT last_updated AS prev_last_updated, state AS prev_state, min(lead_last_updated, strftime('%Y-%m-%d %H:%M:%S', 'now', 'localtime')) AS last_updated, lead_state AS state
              FROM lead_data
            SELECT SUM(CASE WHEN prev_state = '{{state}}' THEN cast(strftime('%s', last_updated, 'utc') as real) - cast(strftime('%s', prev_last_updated, 'utc') as real) ELSE 0 END) AS total_time_in_sec FROM stat_data
          {%- else -%}
          {%- endif -%}
        response_variable: result
      - type: template
        value_template: >-
          {%- if result and result[0] and result[0].total_time_in_sec -%}
            {%- set duration = result[0].total_time_in_sec | int -%}
            {%- set days = (duration // 86400) | int -%}
            {%- set hours = ((duration % 86400) // 3600) | int -%}
            {%- set minutes = ((duration % 3600) // 60) | int -%}
            {%- set remaining_seconds = (duration % 60) | int -%}
            {{ "{0}d ".format(days) if days > 0 else "" }}{{ "{0}h ".format(hours) if hours > 0 else "" }}{{ "{0}m ".format(minutes) if minutes > 0 else "" }}{{ "{0}s".format(remaining_seconds) if remaining_seconds > 0 else "" }}
          {%- else -%}
            unkown
          {%- endif -%}
FAQ
  1. Can gpt modify or delete data?
No, since connection is created in a read only mode, data are only used for fetching.
  1. Can gpt query data that are not exposed in database?
Yes, it is hard to validate whether a query is only using exposed entities.
  1. Query uses UTC time. Is there any way to adjust timezone?
Yes. Set “TZ” environment variable to your region (eg. Asia/Seoul).
Or use plus/minus hours to adjust instead of ‘localtime’ (eg. datetime(s.last_updated_ts, 'unixepoch', '+9 hours')).
References
