I am using Bluetooth with a Sena antenna, and it works quite well… except for some small areas in my apartment.
I would like to extend the Bluetooth coverage by using one of the Raspberry pi zero I have - I used to do that for another domotic system (jeedom) in the past.
Is there a way to set up a Raspberry pi zero as a secondary Bluetooth antenna ?
Have you looked into this? Bluetooth Proxy — ESPHome
I did not, but this would not allow using the R Pi zero, right? If there is a solution on an existing equipment for me, it would be more convenient…
No, it’s on ESPhome. The devices are quite cheap.
I understand, sometimes it is better to change the hardwaare
Which ESPHome device would be the most convenient to use ?
thanks again for the suggestion.
Any ESP32 should do. I use the Atom M5 stack lite cause of the design / size. Check aliexpress.
