Extending WiFi to p1Meter
Hi all
My WiFi doesn’t reach the utility meters.
What are my options? I find a enlargement dongle of 70 euros.
Any ideas?
If wifi doesn’t reach then wire it?
Throwing a cheap repeater???
That’s probably scam! Don’t fall for it. :x:
Ether go wired or wireless (el-cheapo wifi repeater like suggested?) :man_shrugging:
Thank you all. I’m going to try with a long extender rj11 cable. If I can get it through the ceiling, I might get enough WiFi.
I also assume a flaky connection is good enough, it just needs to send some small packages every now and then.
just fyi, mine sends all power data once every second….
is it sending cumulative total or net consumption happened in that second? depending on the data, receiving data in sparse schedules might still work, right?
[16:47:37][D][sensor:093]: 'Energy Consumed Tariff 1': Sending state 116812.91406 kWh with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Energy Consumed Tariff 2': Sending state 269516.06250 kWh with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Energy Produced Tariff 1': Sending state 0.00000 kWh with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Energy Produced Tariff 2': Sending state 0.00000 kWh with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Consumed': Sending state 9.81600 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Produced': Sending state 0.00000 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Electricity Failures': Sending state 15.00000  with 0 decimals of accuracy
[16:47:37][D][sensor:093]: 'Long Electricity Failures': Sending state 3.00000  with 0 decimals of accuracy
[16:47:37][D][sensor:093]: 'Voltage Phase 1': Sending state 228.00000 V with 1 decimals of accuracy
[16:47:37][D][sensor:093]: 'Voltage Phase 2': Sending state 228.00000 V with 1 decimals of accuracy
[16:47:37][D][sensor:093]: 'Voltage Phase 3': Sending state 227.00000 V with 1 decimals of accuracy
[16:47:37][D][sensor:093]: 'Current Phase 1': Sending state 8.00000 A with 1 decimals of accuracy
[16:47:37][D][sensor:093]: 'Current Phase 2': Sending state 17.00000 A with 1 decimals of accuracy
[16:47:37][D][sensor:093]: 'Current Phase 3': Sending state 19.00000 A with 1 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Consumed Phase 1': Sending state 1.71200 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Consumed Phase 2': Sending state 3.81400 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Consumed Phase 3': Sending state 4.29000 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Produced Phase 1': Sending state 0.00000 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Produced Phase 2': Sending state 0.00000 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Power Produced Phase 3': Sending state 0.00000 kW with 3 decimals of accuracy
[16:47:37][D][sensor:093]: 'Gas Consumed': Sending state 95483.64062 m³ with 3 decimals of accuracy
[16:47:37][D][text_sensor:064]: 'DSMR Identification': Sending state 'XMX5LGBBLA4412187776'
[16:47:37][D][text_sensor:064]: 'DSMR Version': Sending state '50'
every second…(slimmermeter)
