Extensive roller shutter control including shading
Hello all,
I have extended my old Blueprint for controlling roller shutters a bit and also added a practical function for shading.
So now a roller shutter can be controlled depending on:
  • brightness value
  • working day / non-working day
  • Resident of the room
  • time window (earliest, latest)
    morning and evening.
    A ventilation mode is also supported if the shutter belongs to a window/door with a corresponding sensor.
For shading are supported:
  • Sun position (azimuth and elevation)
  • Brightness value (possible independently of the upper one)
  • two temperature sensors (e.g. outdoor and indoor temperature or differential temperature sensor)
  • Temperature forecast sensor
Christmas mode is also supported (do not close in the evening if certain criterion is given)
Feel free to try it out. Runs with me with >20 shutters so far largely without problems.
2023-09-13: First release
2023-09-18: fix closing bug with brightness_sensor. small clean-up.
