External access with Traefik
for external access to my HAOS machine, I use this add on: home-assistant-addons/traefik at master · boomam/home-assistant-addons · GitHub
(I am open to suggestion for using another software stack for that, as long as it included automatic let’s encrypt certificates)
Unfortunately, I am not able to get past a error 400.
What I get
  • 400: Bad Request on the browser calling the external URL.
  • Service selected by WRR: http://home.local:8123 when calling the external URL on either http or https (log level = debug).
What I did
  • In my router, forwarded ports 80 and 443 to my home assistant machine (home.local:8123)
  • Use that fileConfig.yaml
http:
  routers:
    httpsredirect:
      entryPoints:
        - "web"
      middlewares:
        - "httpsRedirect"
      rule: "HostRegexp(`{host:.+}`)"
      service: httpsredirect
    homeassistant:
      rule: "Host(`my.home.domain`)"
      entryPoints:
        - "websecure"
      tls:
        certResolver: le
      service: homeassistant
  middlewares:
    httpsRedirect:
      redirectScheme:
        scheme: https
  services:
    httpsredirect:
      loadBalancer:
        servers:
          - url: "http://home.local"
    homeassistant:
      loadBalancer:
        servers:
          - url: "http://home.local:8123"
        passHostHeader: true
inside the container, the traefik.yaml looks like:
global:
  checkNewVersion: false
  sendAnonymousUsage: false
entryPoints:
  web:
    address: ":80"
    http:
      redirections:
        entryPoint:
          to: websecure
          scheme: https
  websecure:
    address: ":443"
    forwardedHeaders:
      insecure: false
api:
  dashboard: true
  insecure: true
serversTransport:
  insecureSkipVerify: false
certificatesResolvers:
  le:
    acme:
      email: "[email protected]"
      storage: "/ssl/traefik/acme.json"
      tlsChallenge: {}
providers:
  file:
    directory: "/config/traefik/"
log:
  level: DEBUG
/ssl/traefik/acme.json looks just fine with a certificate and a key for my.home.domain.
with access logs enabled I get the additional line in the logs:
aaa.bbb.ccc.ddd - - [14/Jan/2026:18:52:12 +0000] "GET / HTTP/2.0" 400 16 "-" "-" 9 "homeassistant@file" "http://home.local:8123" 4ms
  • Set the Home Assistant URL to https://my.home.domain
Thanks for any ideas and help!
Look on the HA logs for more information.
You proably need to whitelist your reverse-proxy
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.0.0.0/8
The error in the log will tell you the IP of the proxy, but 172.0.0.0/8 should work (it’s the ip subnet used by docker/addons)
