lpupi
1
First, i’m a new HA user & i’m french (With a poor english…)
Salvation,
I have installed HA on a VM (Esxi).
Everything is going well with local access.
I would also like to have access to HA from the outside by taking advantage of my domain …
Basically I have a public IP address and DNS-leveled all my subdomains on it.
At the router level, I send all 433 flows (https to a redhat server (with nginx).
At my nginx.conf, I send each subdomain under the right server and the right port.
For the HA part, I therefore tried the following conf:
server {
listen 443 ssl;
server_name domo.sorsdetacoquille.fr 1;
ssl_certificate /etc/pki/tls/certs/sdtc.crt;
ssl_certificate_key /etc/pki/tls/private/sdtc.key;
client_max_body_size 10M;
location / {
proxy_pass http://192.168.1.69:8123/;
proxy_http_version 1.1;
proxy_set_header Upgrade $ http_upgrade;
proxy_set_header Connection keep-alive;
proxy_set_header Host $ host;
proxy_cache_bypass $ http_upgrade;
If I test my config, I find myself on an HA data loading page …
Any ideas ? (I’m no nginx pro, it’s a bit of copy paste.
Thank you in advance for your help.
koying
(Chris B)
2
Are the blanks between “$” and the various “http” copy-paste issues?
If not, remove them.
lpupi
3
hi,
thanks for replie.
yes it’s a copy/paste issue : there are no blanks.
server {
listen 433 ssl;
server_name domo.sorsdetacoquille.fr;
location / {
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
Missed “;” after server name.
Retry after nginx retsart : but now i’ve got a bad gateway …
My test :
PC-17 is my Red Hat server.
koying
(Chris B)
4
Here is my working configuration.
Looks like your problem is websocket.
I suspect proxy_set_header Connection $connection_upgrade;
might solve it.
location / {
include global/proxy_params.conf;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_ssl_name $host;
proxy_ssl_server_name on;
proxy_pass http://backend_ha;
lpupi
5
trying to change ‘proxy_set_header Connection keep-alive;’ by ‘proxy_set_header Connection $connection_upgrade;’
but nginx doesn’t restart (unknown “connection_upgrade” variable)
initialized in your global/proxy_params.conf ?
trying ti define it in my conf :
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
but even “Bad gateway”
koying
(Chris B)
6
Ah, yeah. I have the same map that you tried in my config.
No clue
My actual full config if it can help
log_format halog '$remote_addr - $remote_user [$time_local] '
'"$request" $status $bytes_sent '
'"$http_referer" "$http_x_forwarded_for" "$request_body"';
default upgrade;
'' close;
upstream backend_ha {
server 192.168.3.244:8123;
server {
listen 8143;
listen [::]:8143;
access_log /var/log/nginx/ha.access.log halog;
include global/ssl_be.conf;
server_name <my_fqdn>;
proxy_buffering off;
location / {
proxy_params.conf
ssl_be.conf
ssl on;
ssl_certificate /usr/local/etc/dehydrated/certs/<my_domain>/fullchain.pem;
ssl_certificate_key /usr/local/etc/dehydrated/certs/<my_domain>/privkey.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_dhparam /etc/ssl/certs/dh2048.pem;
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_stapling on;
ssl_stapling_verify on;
add_header Strict-Transport-Security "max-age=15768000; includeSubdomains";
