i want to switch from openhab to HA.
After a install on Proxmox i want to integrate my Sensors.
The Matter Integraton is very good.
Now i want to stat qith my MQTT und Homematic device.
And on my first step, the MQTT i don´t can integrate my external Mosquitto Broker.
I have read some Forum s(like here: External Mosquitto Mqtt Connection Failed) but no Solution.
I use 2024.12.5 core.
Then i go to Settings und Devices. I add MQTT and select “g<ib die Verbindungsdaten manuell ein”.
I fill in all information Hostname, Port 1883, username und password. Then i become am “Verbindung nicht möglich”. No further information, in all test i become once a connect, but by the discover, the error ():
error (mainthread) [homeassistant.components.mqtt.client] failed to connect to mqtt server due to exception: [errno 111] connection refused
When i fill the configuratiion with
mqtt:
broker:
username:
password:
i become:
2024-12-28 19:05:48.570 ERROR (MainThread) [homeassistant.config] Invalid config for ‘mqtt’ at configuration.yaml, line 13: ‘broker’ is an invalid option for ‘mqtt’, check: mqtt->0->broker, please check the docs at MQTT - Home Assistant
Invalid config for ‘mqtt’ at configuration.yaml, line 13: ‘discovery’ is an invalid option for ‘mqtt’, check: mqtt->0->discovery, please check the docs at MQTT - Home Assistant
Invalid config for ‘mqtt’ at configuration.yaml, line 13: ‘discovery_prefix’ is an invalid option for ‘mqtt’, check: mqtt->0->discovery_prefix, please check the docs at MQTT - Home Assistant
Invalid config for ‘mqtt’ at configuration.yaml, line 13: ‘password’ is an invalid option for ‘mqtt’, check: mqtt->0->password, please check the docs at MQTT - Home Assistant
Invalid config for ‘mqtt’ at configuration.yaml, line 13: ‘port’ is an invalid option for ‘mqtt’, check: mqtt->0->port, please check the docs at MQTT - Home Assistant
Invalid config for ‘mqtt’ at configuration.yaml, line 13: ‘username’ is an invalid option for ‘mqtt’, check: mqtt->0->username, please check the docs at MQTT - Home Assistant
Have someone an idea?
With greetings,
Michael
