I cannot seem to hit any external addresses from Hassio – so Telegram, Pushbullet, etc don’t work at all.
I have flashed Hassio to new memory card (twice over a few days).
I have double-checked static IP address and DNS are set in Resin boot (as well as my router), but I cannot seem to hit any external address from Hassio.
Local ping test to Google.com resolve networking just fine.
Only error message is: Unable to find service notify/mytelegram
I have tried to SSH to the local docker image, but cannot seem to get public/private key configured properly.
I am experience a TON of connection problems as well. No idea what is causing it. To make things worse (from a troubleshooting side) is that connections are OK some of the time.
The logs show many errors start with the following exception.
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network unreachable
