Got HA OS via RPi installed and running a stream of data via MQTT broker (Ubuntu machine with RPi Zero 2 W as data collector).
I can easily get the values from the Ubuntu Machine (broker) using Node-RED into HA. HA now reads the data in Node-RED, but how do make this data stream like a standard “entity” so that I can further manupulate it in HA (i.e. send it to my existing Home Assistaint/Google Assistant integration or use in an automation)?
Unable to prepare setup for platform mqtt.sensor: Unable to set up component.
2:07:58 PM – (ERROR) setup.py
Setup failed for mqtt: Integration failed to initialize.
2:07:57 PM – (ERROR) setup.py
Node-RED is reporting (and working) at that topic, here’s a snapshot:
