External URL not working
I can´t make work my external URL if do the configuration from (configuration/general) It doesn´t work when I try to access it appear this:
1
and if y click in retry appear this:
this is the error:
Logger: aiohttp.server
Source: /usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py:355
First occurred: 10:31:56 PM (8 occurrences)
Last logged: 10:31:59 PM
Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 275, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp\_http_parser.pyx", line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
But if I do the config from the configuration.yaml like this:
http:
  base_url: myurl.duckdns.org:8123
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
It works fine but I can´t connect using the local ip
What I´m doing wrong?
Using base_url under http, instead of internal_url and external_url under homeassistant.
See the release notes for v0.110.
I’m not sure if this helps, but I was trying to set up external access to my HA and found the following article, which worked perfectly on the very first try, after everything I did failed: DuckDNS - It's not just me - it's you!
Yes I see that, and because that I try to use the external url under configuration/general like this:
But it doesn´t work. it show the error I upload in the first comment. I´m 100% that my port 443 is open and linked to the ip of my HA
I have the same problem. did you find a solution?
Personally I access HA through
https://xxx.duckdns.org:8123/lovelace/default_view
and my config is
Screenshot - 13_03_2022 , 11_50_44
Please note the https at one place and the http at the other.
