I have few external Venetian blinds with Somfy IO motors.
I have bought a Velux KLF 200 gateway to be able to integrate them with HA.
Somfy does not provide any integration method without connecting to their cloud service so if I would start over again I would definitely avoid Somfy IO-homecontrol products!
but it is too late…
I have added the settings needed for the velux compontet to the configuration.yaml file.
After this I can move up and down all my external Venetian blinds with HA but I can’t change the tilt position of the blinds.
I have tried to call different Cover Control Services on my external Venetian blinds and the following are working fine:
cover.open_cover
cover.close_cover
cover.stop_cover
but the following are NOT working:
over.open_cover_tilt
cover.close_cover_tilt
cover.stop_cover_tilt
Investigating further the issue it seems from the VELUX component code that the last 3 Cover Control Services are not supported in the Velux component code.
"""Support for Velux covers."""
from homeassistant.components.cover import (
ATTR_POSITION,
SUPPORT_CLOSE,
SUPPORT_OPEN,
SUPPORT_SET_POSITION,
SUPPORT_STOP,
CoverDevice,
Am I right?
Does anyone have a solution for this issue?
Do I need to modify the VELUX component to support the manipulation of the tilt position?
Does PyVLX support the manipulation of the tilt position of external Venetian blinds?
My KLF200 firmware version: 0.2.0.0.71.0
My HA version: 0.98.5
