Extra characters in operating_state string
Hello all,
Trying to finish up my thermostat configuration and getting an odd display issue with the operating state. I have a (’ at the beginning and a ',) at the end:
As you can see the fan state doesn’t have the same issue. Here are both of them in the states page:
And here is the relevant config for the display:
    sensors:
      climate_main_operating_state:
        friendly_name: 'Operating State'
        value_template: '{{ states.climate["2gig_technologies_ct100_thermostat_usa_heating_1_8_1"].attributes.operating_state }}'
      climate_main_fan_state:
        friendly_name: 'Fan State'
        value_template: '{{ states.climate["2gig_technologies_ct100_thermostat_usa_heating_1_8_1"].attributes.fan_state }}'
And for the group:
group:
   hvac_main:
     name: 'Main Thermostat'
     entities:
       - sensor.climate_main_fan_state
       - sensor.climate_main_operating_state
Thanks so much for your assistance!
That’s strange - I can’t reproduce that for my thermostat. What if you change up the value template for “Operating State” and use something like:
states.climate.2gig_technologies_ct100_thermostat_usa_heating_1_8_1.attributes.operating_state
It blows up:
16-12-09 18:37:23 homeassistant.bootstrap: Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: expected token ‘end of print statement’, got ‘gig_technologies_ct100_thermostat_usa_heating_1_8_1’) for dictionary value @ data[‘sensors’][‘climate_main_operating_state’][‘value_template’]. Got ‘{{ states.climate.2gig_technologies_ct100_thermostat_usa_heating_1_8_1.attributes.operating_state }}’. (See ?:?). Please check the docs at Template - Home Assistant
Seems to be a known bug for devices that start with a number: template broken for zwave sensor name that starts with a number.. · Issue #2826 · home-assistant/core · GitHub
Ah. Why don’t you change the name in Open Zwave Control Panel?
Gave that a shot and same thing. Updated config (pic looks the same):
    sensors:
        value_template: '{{ states.climate.main_thermostat_heating_1_8_1.attributes.operating_state }}'
        value_template: '{{ states.climate.main_thermostat_heating_1_8_1.attributes.fan_state }}'
group:
   hvac_main:
     entities:
When you put that expression in the template dev tool, do you get the parentheses and comma, too?
Yup:
Ok. The good news then is that it’s not a prob with your template.
Looks like there’s a problem with the code for that device. Weird that it doesn’t show up that way in the states dev tool.
As a duct-tape fix, you could use:
{{ states.climate.main_thermostat_heating_1_8_1.attributes.operating_state | replace("(","") | replace(")","") | replace(",","") }}
Close:
Sigh… Pretty sure you could’a figured that out…
{{ states.climate.main_thermostat_heating_1_8_1.attributes.operating_state | replace("(","") | replace(")","") | replace(",","") | replace(","’"") }}
Probably, but it doesn’t seem to like that:
pi@raspberrypi:/home/hass/.homeassistant $ tail home-assistant.log
16-12-10 00:43:57 homeassistant.util.yaml: while parsing a block mapping
  in "/home/hass/.homeassistant/configuration.yaml", line 111, column 9
expected <block end>, but found '<scalar>'
  in "/home/hass/.homeassistant/configuration.yaml", line 113, column 169
That one I don’t have a clue about. :confused:
right. I replaced the wrong ’
try:
{{ states.climate.main_thermostat_heating_1_8_1.attributes.operating_state | replace(“(”,“”) | replace(“)”,“”) | replace(“,”,“”) | replace(“'”,“”) }}
I had actually caught that and tried it but I get the same error:
16-12-10 15:49:46 homeassistant.util.yaml: while parsing a block mapping
  in "/home/hass/.homeassistant/configuration.yaml", line 112, column 9
  in "/home/hass/.homeassistant/configuration.yaml", line 114, column 167
Are you sure? I just tested and it worked for me. Plug it into your template dev tool and tweak till it works. You’ve got enough there to figure out the syntax for a replace filter.
Yeah, and here’s the super goofy thing. It works fine in the dev tool:
But as soon as I plug it into my yaml file:
    sensors:
        value_template: '{{ states.climate.main_thermostat_heating_1_8_1.attributes.operating_state | replace("(","") | replace(")","") | replace(",","") | replace("'","") }}'
And restart HASS it errors out:
16-12-10 15:58:01 homeassistant.util.yaml: while parsing a block mapping
  in "/home/hass/.homeassistant/configuration.yaml", line 115, column 167
So it worked until you added that last replace? So 3 replace filters work, 4 doesn’t? That’s weird.
Does anyone know if there’s a Jinja filter for regex replaces?
Yes, it works fine just still has the single quotes on either end. Once I add in the 4th replace it dies - even though the dev tools show it as working as expected. :confused:
ah - that’s the problem. The single quotes!
Work on it using the template tool. You’ll need to do some trial and error.
Here’s how you escape a character:
(basically {{ “CHAR” }} )
Strike that. Just do this:
value_template: >
That removes the need for single quotes in your YAML
Ahh beautiful!
Thanks so much for your assistance and patience with me! I’m still very much a n00b.
