Extra data in light custom UI
Most of my zwave light have power measurement.
I don’t want to spend the screen estate for a separate power consumption sensor.
So I added an option to add extra data from attributes to the UI:
As you can see I’m not a UX designer - any UI advice is welcome.
The code is here: https://github.com/andrey-git/home-assistant-custom-ui
You can hide the power sensors and only view the total (or per room) using the template sensor, I know it’s not what you asked for, but it’s the way I have it set-up currently.
