I’d like to stick a relay in my hot tub circuit, because it sometimes trips. If this happens in the winter, it can lead to frozen pipes and a lot of damage. The hot tub draws up to 75A when both pumps start. I think it’s in the range of 30-50A otherwise, but I’m not sure.
I’ve only seen relays in the 10A range. Does anything like this exist??
I’ve also shopped around for high amperage Z-Wave / Zigbee and it’s pretty hard to find. There are some DIY routes as well where you can use a smart device to control a larger relay that takes care of this. Anyway, if you can find out exactly what the amperage is for your two pumps then you might find one of these off-the-shelf heavy duty units useful:
