Hey Guys,
I’ve been trying various variations of this but still getting the same error on config validation. Zwave-JS is the platform. I have tried with ’ ’ and with " " and with a number parameter and with this word parameter. Any help would be really appreciated. ’
Yes, it’s much easier and reliable to use UI mode first, then copy the generated YAML, if you want to use it for an automation. My suggestion to post the correct formatting is to identify if it is an indentation problem. If you start with the UI, it will format everything properly.
