The $entity()
variable is only available in the home assistant nodes. Also when using the nodered nodes the path changes from attributes.longitude
to data.attributes.longitude
Inside ha nodes omit data if it is part of the path, in nodered, use it. Most of the time. There are also differences between JSON and Jexpression aka jsonata
[{"id":"2a3de46120e39c8e","type":"api-current-state","z":"60f2d2277843c698","name":"","server":"6b1110b5.183a4","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"device_tracker.pixel_7_5","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":440,"y":2620,"wires":[["36ef6e34a902d7ec"]]},{"id":"2a5d383dd1367854","type":"inject","z":"60f2d2277843c698","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":2620,"wires":[["2a3de46120e39c8e"]]},{"id":"36ef6e34a902d7ec","type":"change","z":"60f2d2277843c698","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t \"lat\": data.attributes.latitude,\t \"lon\": data.attributes.longitude \t}","tot":"jsonata"},{"t":"delete","p":"data","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":2620,"wires":[["1e2e6826354e97f1"]]},{"id":"1e2e6826354e97f1","type":"debug","z":"60f2d2277843c698","name":"debug 32","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":860,"y":2620,"wires":[]},{"id":"6b1110b5.183a4","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
