My home-assistant_v2.db file is now near 8GB in size, accumulating data over years of playing with home assistant.
before i delete the file, there is ONE data set which I would like to keep: my electricity usage data (I have a energy usage monitor installed on my break circuit). It is just a single entity.
how do I merely extract this single data set and export it to a new “home-assistant_v2.db” file?
It is a SQLLite DB. You should be able to write a sql select to get the data out and back into a new one.
Maybe this can help finding the data. (I have not used it)
This sounds similar to a post that I posted, but unfortunately did not get a response. I would really love to be able to have an offline huge database and a smaller on HA itself so tagging this to see if someone would know a solution!
